Home -> Forums -> Construction -> Start Construction -> 1:2:4 mix or 1:3:3 mix
Sat Mar 15, 2014Total posts : 3
navneet
navneet
Topic: 1:2:4 mix or 1:3:3 mix
I saw builder use 1:3:3 concrete mix Instead 1:2:4 concrete mix for residential buildings slab.
what is your comments ?
Sun Mar 16, 2014Post  #1
Ahmed
Ahmed
HI Navneet
There are 3 standards in india
1. M25(1:1:2)
2. M20( 1:1.5:3)
3 M15 ( 1:2:4)
M20 is the minimum for PCC and RCC for Residentail building
Sun Mar 16, 2014Post  #2
navneet
navneet
thankyou ahmed sir for responce .
I want to know, Is this right mix (1:3:3)?
persuade the demerits and merits(if yes) for this mix
request all the experienced member give your opinion about 1:3:3 mix
Tue Mar 18, 2014Post  #3
Dear Navneet
      As stated by Sh. Ahmed the standard mix is
1. M25(1:1:2)
2. M20( 1:1.5:3)
3 M15 ( 1:2:4)
But as you say about 1;3;3 In this mix sand contents are more and this mix is OVER SANDED and as much sand than requirement reduce the strength. Generally contractor use over sanded for easy finish.
4365
WHAT IS THE RATIO
1763
1457
3275
3769
concrete mix design software
3791
1665
Last answer on 7/3/2020 11:11:05 PM. by Navneet Jharia. Forum started by Sandeep
1686
2135
READY MIX PLASTER
2001
Dear Sir iam sr.civil engineer with adequate experience.so please tell me the pr
Last answer on 1/16/2021 1:07:32 AM. Forum started by SANJAY DUSANE
3350
Study Room Vastu
Last answer on 1/29/2021 7:27:25 AM. by dorishall. Forum started by Avinash Ojha
1763
2547
Water for Construction
4372
Ready Mix Concrete
6462
4240
mix design of rcc slab
Last answer on 7/31/2012 11:18:03 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
2157
Ready Mix Concrete
Last answer on 7/4/2020 2:18:20 AM. by S L Gupta (Civil Engg). Forum started by Vishwanath
3199
Ready Mix Concrete
2466
3309
2133
2059
Concrete Mix Ratio
Ready
Ready Mix Concrete
CONCRETE
Tips for Oil Bound Distemper
