Mon Aug 12, 2013Total posts : 1
jk
jk
Topic: 12"x9"x12'height piller steel design in lblack soil
Fri Aug 16, 2013Post  #1
Dear Jk
      The design of column/ pillar depends upon the load bear by it.However use 6nos 16 mm dia MS steel bars in column.
4134
Last answer on 7/3/2020 10:23:02 PM. Forum started by V.BASKER
2995
4940
COLUMN AND STEEL DESIGN
4940
2689
Last answer on 7/2/2021 3:17:17 PM. by B Thakar. Forum started by minhaj sk
3510
1836
chick door
3721
1945
Last answer on 7/3/2020 11:23:38 PM. by JAI PRAKASH. Forum started by rajesh
1992
Residential complex
1586
i want to knw cost about making a piller height 4 feet and 8*8
Last answer on 6/9/2021 8:12:51 AM. by ]Greis. Forum started by RUPESH RATHORE
2317
Root of tree
Last answer on 7/7/2021 6:18:23 AM. by Navneet Jharia. Forum started by paresh
1892
Foundation Digging Help
Last answer on 1/25/2021 8:47:56 AM. by Shivaraj. Forum started by Shivaraj
3033
3404
house Map
Last answer on 7/4/2020 2:14:05 AM. by Navneet Jharia. Forum started by m raza
2322
18
Type
Which are various brands of pipes for drainage of soil water?
Brands of pipes for drainage of soil water-C.I. Pipes-CIC..........
HSD
Precautions
Steel
Steel Roofing
Porch
Porch Designs
