| Electrical Fitting and Cable Wiring We all need power to run electrical appliances and different gadgets in our home. For proper distribution of electrici.. |
| Earthing In Electrical Fitting In electrical works, earthing or earthed means to connect electrical system to general mass of earth in such a manner .. |
Which are various types of door viewers for houses? The Mini Scope door viewer is a unique 200 degree peephole that is designed to fit thin doors.
| Sanitary Appliances And Their Specifications Sanitary appliances are fittings used for collection and discharge of soil or waste matter. These appliances may be gr.. |
