Home -> Forums -> Construction -> Cement Concrete -> 1400 Sq.ft RCC roof how much Steel,Sand,Jally & Cement required?
Mon May 09, 2016Total posts : 3
Mohan
Mohan
Topic: 1400 Sq.ft RCC roof how much Steel,Sand,Jally & Cement required?
Dear Sir/Madam,
               1400 Sq.ft walls Material estimation advise.
Mon May 09, 2016Post  #1
Dear Mohan
       What information do you need at one place you write Material for RCC and at one point wants wall material. write clearly your question.
Mon May 09, 2016Post  #2
Mohan
Mohan
Post subject: 1400 RCC roof Material Estimation with Cost
Gupta Sir,
                   My House Construction was Completed at Basement level now from Base level to wall construction & Roof balance now. For that how much materials required that i need information sir.
1.1400 Sq.Ft area Rcc Roof how much Jally,Cement,Steel & Sand required?
2.Below the Rcc roof wall Construction how much bricks,cement&sand required say Approx?
Hope you will uderstand.
Thanks.
Tue May 10, 2016Post  #3
Dear Mohan
       For 1400 sft area slab  1;2;4 ratio with out beam taking 4.5'' thickness the material is
cement= 90 bags, Bazri= 500cft, coarse sand= 300 cft, Ms steel bars= 1500 kg.
13716
3477
11020
191760
1847
2844
Steel calculation
1443
4348
WHAT IS THE RATIO
42566
Labour Cost for Roof RCC work
2729
2439
estimate
705
1574
How much steel required for 40*38 sq.ft Slab? how much material required.. cemen
Last answer on 1/5/2022 12:38:24 AM. by S L Gupta (Civil Engg). Forum started by Mani Kumar
1101
Last answer on 7/23/2018 11:32:12 PM. by S L Gupta (Civil Engg). Forum started by Mani Kumar
RCC + Brick work estimate for 2400 sq ft construction- Update
Last answer on 5/7/2014 4:12:37 PM. Forum started by nilesh
29812
4623
3461
Cost of concrete walls
1767
STP
3096
3639
4335
rate comparison
3187
Concrete Mixture
3126
sloping roof
2075
6433
2352
leakage in new slab
1511
Guide me
4994
2512
Civil Eng Stair Design
2512
2319
Related to Sunken Slab
1844
1988
Concrete Hollow Block Masonry
2398
roof concrete
3190
Ready Mix Concrete
What is acre
Type
Steel
Steel Roofing
