1430 sqft plot, north common wall; south TP road; east side soc. road west side
Sat Mar 29, 2014Total posts : 2
sb mehta
sb mehta
Topic: 1430 sqft plot, north common wall; south TP road; east side soc. road west side
1430 sqft plot, north common wall; south TP road; east side soc. road west side soc. road; so pl. guide me for duplex plan as per vastu shashtra. 700 sqft plinth;
Sat Mar 29, 2014Post  #1
Post subject: Dimensions of plot
Dear Sir, hello..Kindly send dimensions of plot  i.e. Length and width also to plan a  duplex.. or go through Gharexpert to choose plan according to your requirements... .regards
Tue Apr 01, 2014Post  #2
Dear Mehta
East Side 43 fit or west side road view 39 fit or south
Last answer on 2/28/2017 2:57:47 PM. by S L Gupta (Civil Engg). Forum started by Prashant Kumar
2675
plot having west side &south side road
Last answer on 8/21/2014 2:42:37 PM. by Dilavarsinh Vaghela. Forum started by rahul kulkarni
3276
my plot east 36 north 50. north and west 2 side road, i want 4 side open pls sug
Last answer on 11/3/2014 5:15:20 PM. by Ashok. Forum started by ravi
11992
Last answer on 1/5/2022 9:03:47 PM. by S L Gupta (Civil Engg). Forum started by ajay kalra
3763
My plot is south east extended,extended in east with two side road in east
Last answer on 10/18/2016 5:22:59 PM. by priya. Forum started by A K Sah
2232
Please let me know if its advisable to construct house south-north 27 and east-w
Last answer on 12/22/2009 3:57:57 PM. by Mani . Forum started by nanjundaswamy k
1851
residential plot in east, road on west and south side.park on northside is it va
Last answer on 1/11/2014 6:10:00 PM. by Navneet Jharia. Forum started by Vanitha
2743
Last answer on 8/11/2017 2:15:35 AM. by HOME. Forum started by parveen sharma
2469
My plot Size 30X57 west side road 30 Feets and south side 56 feets, please sugge
Last answer on 2/27/2015 4:09:15 AM. by JAI PRAKASH. Forum started by Lakhvinder
4273
Last answer on 8/12/2020 2:58:49 AM. by baba morris. Forum started by geetha
2155
Last answer on 10/25/2021 1:47:12 AM. by JAI PRAKASH. Forum started by mgmishra
4520
2044
30×41 north facing plot 2 side road north and south. i need 3 room with puja gha
Last answer on 11/1/2021 5:47:56 AM. by S L Gupta (Civil Engg). Forum started by sumit
3158
2241
i have purchsed daigonocaly plot for residential purpose there is south corner i
Last answer on 12/6/2010 1:50:39 PM. by S L Gupta (Civil Engg). Forum started by bipin brahmbhatt
2442
Last answer on 5/3/2016 12:15:23 AM. by JAI PRAKASH. Forum started by Anuj
2151
Map for Gaumukhi Plot
Last answer on 7/4/2020 2:28:56 AM. Forum started by akshay
2652
map for gaumukhi plot
Last answer on 7/4/2020 2:28:35 AM. Forum started by akshay
25
31
What are various designs available in side hung doors?
Designs available in Side Hung Doors.....
What are the various accessories recommended for Aluminium doors?
Various accessories for Aluminium doors :Door Handles,Door Fasteners,Door Viewers....
Centering
Fire
Fire Extinguisher
Fire Extinguisher help avoid accidental fire in the kitchens or homes. It extinguishes not only the fire but saves our..
