Raw Material
Fri Jul 01, 2016
Mohan
Topic: 1680 Sq.ft RCC Slab required Material with BOM
Gupta Sir,
Please Provide required Materials for 74'X20' = 1680 Sq.Ft RCC Slab 1.Cement ,Jally,Sand & Metal etc?
2.For G+1 Building Construction How much Thickness Rcc required 1st floor & Roof?
3.RCC roof what thickness rebar with how much quantity required for 74'x20' RCC?
Fri Jul 01, 2016
Dear Mohan
For 1680 sft area slab with 5'' thick slab with cement concrete mix 1;2;4
Cement= 120 bags.
Coarse sand=320 cft
Bazri or jally=640 cft.
2. 5'' thickness
3. 12mm and 1o mm MS steel bars 2000 kg aproximately.
Fri Jul 01, 2016
Mohan
Post subject: Steel requirement
Gupta sir,
Gharexpert web site estimation software giving 3200 kg steel for 1680 Sq.ft Rcc is it correct sir.
Mon Jul 04, 2016
Dear Mohan
Estimator steel quantity is for column, beam, lintel and slab i.e for whole house construction requirement. The 2000 kg M S Steel is required for Rcc slab/ roof.
9158
Last answer on 8/20/2016 12:41:02 PM. by
Mohan
2866
Steel calculation
Vamshidharreddy
191901
Last answer on 1/23/2022 3:32:01 AM. by
Bimlendra Jha
2276
swarup chakraborty
2772
Last answer on 7/12/2018 5:49:08 PM. by
Hameed
2557
Last answer on 10/15/2017 1:22:37 AM. by
gautam kumar
gautam kumar
13756
Last answer on 1/26/2017 11:24:59 AM. by
Madhankumar
upendra
2407
Last answer on 8/5/2015 4:49:45 AM. by
sanjesh
2185
Marble required for flooring
Last answer on 1/7/2022 12:44:11 AM. by
K. Basu
2812
Last answer on 12/31/2020 2:51:38 AM. by
SHAILESH
3107
Last answer on 10/5/2020 10:59:59 PM. by
DEVANSU
Last answer on 6/9/2016 11:04:10 PM. Forum started by
Vignesh
42599
Labour Cost for Roof RCC work
Last answer on 1/1/2018 11:04:37 PM. by
kamathak2002
4836
Last answer on 7/9/2020 10:10:27 PM. by
jptallam
1592
How much steel required for 40*38 sq.ft Slab? how much material required.. cemen
Last answer on 1/5/2022 12:38:24 AM. by
Mani Kumar
1160
Last answer on 7/23/2018 11:32:12 PM. by
Mani Kumar
premkumarlen
9893
Last answer on 9/19/2020 12:43:29 AM. by
shaik khaja nayab rasool
rishi
2992
Basement Interior Design
Last answer on 11/26/2010 2:58:05 PM. by
S.C.Chawla
Boby
3075
RCC roof
Dinesh Bhadu
1971
Marriage hall construction
chandana kumar
2537
Function Hall
Last answer on 6/14/2021 7:48:53 AM. by
Janette
Mark Paraon
4201
Mohan Bhagwat
2189
Last answer on 11/19/2020 1:18:18 AM. by
Aamir
2038
Estimate
Last answer on 7/3/2020 10:09:08 PM. by
amzad
amzad
3073
Steel
Last answer on 7/2/2020 10:08:44 PM. by
EvaR
use of tmt bar
sonu.211
1643
work turned out by labour
Last answer on 5/15/2017 1:35:22 PM. by
carola braats
2457
estimate
raj
1762
mohd asif
2992
3606
Last answer on 5/26/2016 3:18:53 PM. by
naresh
1943
Cost of Steel construction
Last answer on 4/22/2016 11:27:17 AM. by
VikasUmate
1613
Last answer on 12/17/2015 2:49:59 PM. by
sushantsah
2136
READY MIX PLASTER
Bimlendra Jha
1865
Last answer on 3/1/2015 8:14:42 PM. by
baskar
2223
zero slump concrete
Malik Usman
What is acre
