Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> 17'-6" length & 17'-0" width dining hall.
Fri Oct 17, 2014Total posts : 1
R.R
R.R
Topic: 17'-6" length & 17'-0" width dining hall.
Sir.
I want to know what size/depth is required of roof beam & thickness of RCC Roof slab 17'-6"  length & 17'-0" width dining hall.
I am attached the Column lay out.
Attachments: Column Layout.jpg on Fri Oct 17, 2014,&n
Fri Oct 17, 2014Post  #1
Dear R R
         The size of beam and slab can be calculated by structural engineer by designing the same with load factor. How ever tentative beam should be 9''x 18'' with 2no steel bars of 20mm and 4 bars of 16 mm with 8mm ring 4'' center to center. slab thickness should be 5''. In room 17'x 17' you should lay hidden beam in slab 18''x6'' with 4no 16 mm steel bars at top and bottom. Use cement concrete mix 1;1.5;3.
6126
Last answer on 10/5/2021 3:01:31 AM. by Alexander Graf. Forum started by ravi garg
2137
my septic tank in dining hall
Last answer on 4/30/2011 9:39:07 PM. by S L Gupta (Civil Engg). Forum started by rohitraj
2305
Colour Combination
Last answer on 7/3/2020 10:48:40 PM. Forum started by sarita.angadi
2190
Last answer on 11/18/2013 10:57:21 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
1922
Last answer on 11/18/2013 10:38:53 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
2068
Is 50feet length or width not good for business?
Last answer on 5/22/2017 1:40:42 PM. by S L Gupta (Civil Engg). Forum started by L.GANESAN
2673
Last answer on 5/1/2013 12:09:55 PM. by macbul. Forum started by Rajendran
1692
Query if the plot size is good for constryuction
Last answer on 3/5/2016 10:34:16 PM. by JAI PRAKASH. Forum started by NIRMAL
1892
Last answer on 3/30/2016 12:19:00 PM. by shaikomer. Forum started by shaikomer
1660
my plot is north face, 29" width and 50"length and i want to make it in proper w
Last answer on 2/7/2016 10:39:10 PM. by JAI PRAKASH. Forum started by hirdesh
1683
site width 46.3 ft ,length 55 ft (east) please provide me 2 bedroom plans.
Last answer on 11/25/2015 9:30:28 PM. by JAI PRAKASH. Forum started by krish
1613
Last answer on 3/8/2017 11:11:29 AM. by S L Gupta (Civil Engg). Forum started by kirankumar
3838
Roof Beam
5577
Last answer on 11/3/2014 11:55:58 AM. by seema tyagi. Forum started by balaji
3311
sir,my plot size 15 width and 60 length east facing please provide best home de
Last answer on 8/25/2015 6:09:27 PM. by JAI PRAKASH. Forum started by naresh
1814
i have a 8marla plot length 64ft width 34 ft front street 40ft pls send me desi
Last answer on 4/18/2015 10:20:29 AM. by himanshu. Forum started by Rao Rafique Ahmad
2087
Sir I have a plot length 55.9' and width 17.4' . Can u guide me for a house map
Last answer on 4/20/2015 12:31:34 PM. by seema tyagi. Forum started by Rakesh Singh
3610
5812
3793
9885
2670
4628
4143
2866
5008
3657
1865
2801
2610
2374
2463
2638
1808
3608
6254
Dining
Dining Chairs and Bar Stools
Dining
Dining Room
Dinning room creates cozy atmosphere when decorated with refreshing flowers. Use tremendous ideas and designs which gi..
Dining
Dining Room Lighting
Dining room lighting creates a wonderful impact in your dining area. There are some interesting ways of lighting by wh..
Dining
Dining Table Decorations
One of the quickest ways to embellish your interior is dining table decorations. Dining table decorations give warm an..
Dining
Dining Furniture
Dining room furniture makes your interior stunning .New designs, shapes and colors of dining furniture make the room l..
It is easy to decorate where the space is adequate but decoration of a small dining room is a challenge. It is an art ..
Crystal
Crystal Chandelier : Sparkle your Dining
Crystal chandeliers give grace, lavishness and spark to your dining room. With a charming and elegant crystal chandeli..
Dining
Dining Room Ceiling
