Home -> Forums -> Construction -> Start Construction -> 2 star budget hotel on a plot of 32 ft x 52 ft (3 side open) East facing
Mon Jan 05, 2015Total posts : 2
raaj
raaj
Topic: 2 star budget hotel on a plot of 32 ft x 52 ft (3 side open) East facing
I eed a elevation plan and room plan for above mentioned, the structure will rest on pillars, it will have 3 floors with 7 rooms on each floor with attached toilets in all rooms.
1) The ground can be used for partially reception and rest for shops.
2) The lift and staircase will be on the 52 ft side, at the corner.
3) The corridor will pass thru the centre of the 52 ft side, dividing the rooms on either side. 3 rooms on one side, and 4 rooms on the other side.
Initially it will have the pillar structure and the mezzanine  floor, the balance 2 story will be built at later stage.
This plot is in SIDCUL, in Haridwar, pls suggest an architect who has built budget hotels.
tks n rgds
Raaj/mob 09999040422
Wed Jan 07, 2015Post  #1
Post subject: Gharexpert services
After
completion
of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
Fri Jan 09, 2015Post  #2
The costing would be around 60-70 lacs.
2250
PLAN FOR EAST NORTH ROAD 32 FT WIDE AND 45 FT DEPTH
Last answer on 6/3/2015 9:59:12 AM. by seema tyagi. Forum started by jagdish chand
2547
Last answer on 3/2/2015 12:09:44 PM. by seema tyagi. Forum started by Alok
3304
can u plz send me a house plan for 32*38 ft west facing plot
Last answer on 7/4/2020 1:59:49 AM. by HOME. Forum started by sujitha
4529
Last answer on 7/2/2020 10:07:35 PM. by S L Gupta (Civil Engg). Forum started by Pavan Kumar V
12145
41*43 sqr ft north face only850sq ft small budget house
Last answer on 11/23/2016 12:00:28 PM. by Beenu Phogat. Forum started by kannan
2977
map for plot
Last answer on 1/24/2014 3:43:14 PM. by S L Gupta (Civil Engg). Forum started by jagdish chand
1906
I want to construct a Hotel on NH side with 125 Ft breadth and 50 ft depth pl su
Last answer on 8/14/2014 12:25:23 PM. by S L Gupta (Civil Engg). Forum started by JAGDISH JASROTIA
1614
glass type plot which measurment is east-15,west-21, north-52, south-51 feet and
Last answer on 3/27/2017 6:38:26 PM. by Saurav anand. Forum started by jitendra kumar
3820
2075
SE CORNER IF LENGTH MORE WHAT WILL BE HAPPEN ACCORDING TO VASTU?
Last answer on 12/16/2020 8:20:56 PM. by Nageshwar. Forum started by sasikumar.arumugam75
1164
3068
2404
3580
my plot size 18*32 feet north face 18 feet rastaplease sugest
Last answer on 10/12/2016 2:40:37 PM. by sandeep singh. Forum started by arunmishra
1918
CONSTRUCTION DESIGN
Last answer on 3/8/2017 2:40:59 AM. by S L Gupta (Civil Engg). Forum started by MANISHA
1773
842
Sir I have a plot size 24x65 west facing and a 6 ft gali on left (north side)Ple
Last answer on 7/30/2020 8:16:06 AM. Forum started by S P Srivastava
2195
Construction plan
Last answer on 12/20/2013 2:54:59 PM. by S L Gupta (Civil Engg). Forum started by Dr Ranjan Biswas
3309
can anybody pls send me the house plan of 28 front east facing by 71 sq.ft plot
Last answer on 9/25/2012 11:05:19 AM. by Amit Hasija. Forum started by sweta agrawal
2451
3273
3284
4429
3975
2197
2699
4210
5167
2378
2294
1996
2447
2114
3194
2046
12514
2164
2010
2726
What is acre
Hotel
Hotel reception designs
The texture, color and shape of the reception in your hotel must reflect a mood that is appropriate for its function. ..
Hotel
Hotel lobby lighting
Lighting plays a pivotal role in an eye-catching hotel lobby. Lobby lighting is a special challenge for designers.
Window
Window Air Conditioner
When choosing the room air conditioner, size is important. Many people buy an air conditioner that is too large or too..
Star
Star Contributors
GharExpert.com would like to thank Rajni Jhabak, Amika Rai and Love Thy Community for their contribution to GharExper..
Porch
Porch Designs
