Home -> Forums -> Construction -> Layout and House Plans -> 24' x 53' - Size and placement of column and beams
Mon Aug 22, 2016Total posts : 2
Amir Rehman
Amir Rehman
Topic: 24' x 53' - Size and placement of column and beams
The size of plot is 24' x 53' (Front is 24')
I would like to know the size and placement for columns and beams for above plot. I want to construct basement, ground and 4 floors above ground floor (i.e. 6 floors including basement).
I also would like to place all columns in outer walls only so that I can change interior design whenever i want.
Tue Aug 23, 2016Post  #1
Dear Amir
           The design of R C C columns,  footing, beams and slab is designed according to load bear by them taking factor of safety from earth quack, bearing capacity of soil Span of column, length of beam etc in consideration. For basement and other 5 floors or  stories it is better to take design from structural engineer. When you are spending billion of rupees than do not take risk for design to spent a nominal expenditure. design can save your money at long run and a tentative design we offenly  use more steel than require and some time it is dangerous..
Tue Aug 23, 2016Post  #2
Amir Rehman
Amir Rehman
Dear Mr. Gupta,
Thank you for your professional answer. I have attached the snapshot of the building along with the basic layout plan and CAD files. I am very much interested to update the plan regarding placement and size of beams and columns.
Thanks,
Amir
Attachments: ,j.xps Tue Aug 23, 2016,
H-13 Plaza Model 5.skp Tue Aug 23, 2016,
Plan X1.dwg Tue Aug 23, 2016,&n
2464
My home is T type fernt size Is 10.75 *30 after 30 fit size is 39*53 pl advoise
Last answer on 3/16/2011 2:32:10 PM. by Mohini Sharma. Forum started by pukhraj tater
2296
I hv a singhmukhi west facing plot ,size-24(west),19(east),70(north
Last answer on 5/15/2015 10:14:12 AM. by seema tyagi. Forum started by achintya prakash mishra
1620
North facing 24/45 size map
Last answer on 6/14/2016 12:04:42 PM. by S L Gupta (Civil Engg). Forum started by anilkumawat
2783
Construction House plan require for G+1 for plot size of 31* 53
Last answer on 11/29/2016 6:16:06 PM. Forum started by baji
3303
10048
2702
2719
3795
2083
help
Last answer on 1/9/2015 12:09:16 AM. by JAI PRAKASH. Forum started by Asif
1763
plot size 24' x 49' west facing
Last answer on 12/17/2015 3:02:13 PM. by JAI PRAKASH. Forum started by r c vedwal
1334
771
Plot size is 60 x 65 ft. Built up area will be 24 x 27 ft. please provide me des
Last answer on 9/29/2020 6:02:58 AM. Forum started by Venkatesan
3837
Roof Beam
3623
2860
Column Size and distance
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Centering
Right size cupola
Dining
Dining Room Ceiling
