Home -> Forums -> Construction -> Layout and House Plans -> 25*35 sft floor map
25*35 sft floor map
Sun Aug 28, 2016Total posts : 1
Hemant Rathore
Hemant Rathore
Topic: 25*35 sft floor map
Kindly help me out to find a perfect house plan for 25*35 sft that is 875 sft house. Kindly give suggestions for double story.
Mon Aug 29, 2016Post  #1
for to view all plans click here:-
if you need customization in any plan of these please send us your details on support@gharexpert.com.
Thank you.
1368
East facing 2bhk 25×35
Last answer on 7/4/2020 4:25:38 AM. by S L Gupta (Civil Engg). Forum started by Dr liyakhat ali
13483
Last answer on 7/3/2020 11:13:29 PM. by S L Gupta (Civil Engg). Forum started by Vijay
2486
i want a vastu plan for north facing plot N-45,S-35,E-25,W-25 is this a good plo
Last answer on 2/3/2014 10:57:56 PM. by acharya :- keshava. Forum started by dev
1964
north to south face 4 bedroom plans 1800 sheet 48 chorai 35 lainth map images
Last answer on 2/25/2015 9:23:56 AM. by seema tyagi. Forum started by neelam
19298
40 feet broad and 25 feet depth and is north facing plot please tell me the map
Last answer on 10/30/2014 10:06:26 AM. by seema tyagi. Forum started by amy ram
2535
HOUSE MAP
Last answer on 7/2/2019 11:44:00 PM. by S L Gupta (Civil Engg). Forum started by mohit pal
3559
north facing plot map size 25*50sqare yards
Last answer on 6/15/2013 8:58:08 PM. by arvintacker. Forum started by anjani sharma
11571
2056
Last answer on 1/8/2018 11:06:10 PM. by S L Gupta (Civil Engg). Forum started by ravikumar
3132
1898
about house map
Last answer on 12/12/2013 6:18:06 PM. by Navneet Jharia. Forum started by vikash singh
1267
25*25 only ground floor
Last answer on 8/29/2016 2:27:38 PM. by Beenu Phogat. Forum started by mayur wadhe
2003
please send map land size15x50 total 450 Sft. withr Basement parking
Last answer on 10/6/2014 1:04:05 PM. by seema tyagi. Forum started by arvind Mishra
2133
size of house planned 35 ft front and 45 ft depth with 1st floor
Last answer on 5/12/2016 6:07:13 PM. by Lingraj Halli. Forum started by ROHIT KUMAR
1452
2332
my plot is 25*23 size vastu plan and frunt elevation degiene in groud floor my
Last answer on 2/7/2016 10:36:39 PM. by JAI PRAKASH. Forum started by sanjay sinha
1952
good evining and good day my polot size 31*72 feet plz need me floor map
Last answer on 6/9/2015 11:09:22 AM. by seema tyagi. Forum started by Muhammad Iqbal
633
Need a plan for plot size 45ft roadside and 35 ft depth facing west, single floo
Last answer on 2/19/2021 5:39:57 AM. Forum started by Kiran Tankasali
2625
Please suggest house Map for ground floor plot Size 10x22.5 feet
Last answer on 8/4/2016 5:21:11 PM. Forum started by Gopal Upadhyay
2671
2908
2173
2165
2762
4492
1872
2268
2239
2745
3444
2342
1945
2200
3579
2306
2069
2778
1535
2106
Terrazzo
Refinishing Hardwood Floors
Checklists for flooring
Comparison
Appropriate
Linoleum
Linoleum Flooring
Linoleum flooring is a popular choice when you are looking for style and ease at the budget. You can choose any color ..
Choose
Choose Flooring for your Kitchen
Kitchen flooring should be fit into the kitchen design in such a way that will work according to your personal needs a..
Oak
Oak Flooring
A beautiful, elegant and sophisticated option of flooring adds to the value of your home. Oak flooring is such a choic..
Drawing
Drawing Room Flooring
