2500sq feet banglow plan 4 bed room
Fri Jan 18, 2013Total posts : 1
bobade umesh
bobade umesh
Topic: 2500sq feet banglow plan 4 bed room
Mon Jan 21, 2013Post  #1
Post subject: Use gharexpert readymade plans of bungalows
We have launched ready made plans on our website.
We have service for the construction cost estimate which would give you the brick by brick cost calculation.
Our detailed cost estimate pricing is based on the built up area of the house and price slabs given below:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.25 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.75 per sq.ft.
Above 10000 sq.ft area= Rs.1.25 per sq. ft.
We will take almost 10 business days to prepare the detailed cost estimate.
For preparing the detailed cost estimate, We need the following documents from you:
3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Please supply floor plans.
7. Also supply Exterior elevation and structural drawings if possible.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
If you have a question,send an email to Support@GharExpert.com
1648
I need a house plan for 25×40 feet.North facing.but only for ground floor.i want
Last answer on 4/4/2018 1:18:43 AM. by S L Gupta (Civil Engg). Forum started by Gujjalaraja
11719
30*61 feet west facing please give me map with 3 bed room
Last answer on 10/11/2020 7:24:29 AM. by Beenu Phogat. Forum started by cm singh
7842
2477
east facing residential house plan for double bed room with vastu required
Last answer on 5/5/2016 2:14:48 PM. by Anany goel. Forum started by SatheeshB
1853
Last answer on 12/24/2015 4:17:23 AM. by JAI PRAKASH. Forum started by paramesh
1564
I have 25feet x 45feet west facing road, how best i can plan 2 bed room of singe
Last answer on 1/4/2018 11:38:21 PM. by S L Gupta (Civil Engg). Forum started by Murali
1401
dear sir can u give me idea for 890 sqr foot(30x32) size. which is in 2 bed room
Last answer on 3/3/2017 1:55:44 PM. by S L Gupta (Civil Engg). Forum started by Sunder singh
1954
Last answer on 1/7/2017 3:42:26 PM. by Beenu Phogat. Forum started by BALDEV RAJ
1691
Query if the plot size is good for constryuction
Last answer on 3/5/2016 10:34:16 PM. by JAI PRAKASH. Forum started by NIRMAL
2963
Last answer on 10/2/2009 10:14:12 AM. by sani. Forum started by Gaurav Baide
4384
2943
which direction is good to keep the bed OF master bed room
Last answer on 9/28/2012 12:31:30 PM. by Jimwoo. Forum started by kesar
6140
my plot size 35x70 feet north east facing singel 30 feet road iam intrusted sing
Last answer on 10/20/2016 6:02:35 PM. by Gunjan Utraja. Forum started by sajjan kumar
2609
yes i would like to ask you about my bed room furniture bcoz bed room size is 13
Last answer on 7/4/2020 12:17:54 AM. by Amit Hasija. Forum started by Ashish Gupta
3257
What should the dimensions for Kitchen, Bed Rooms, Living Room
Last answer on 3/21/2012 9:35:03 PM. by S L Gupta (Civil Engg). Forum started by Neelakantan
3086
PLZ SEND SOME POP DESINE FOR LIVING ROOM ,KITCHEN AND BED ROOM
Last answer on 7/3/2020 11:32:54 PM. by Swati Satija. Forum started by ASHOK CHAWLA
3834
Last answer on 6/28/2013 1:44:04 PM. by S L Gupta (Civil Engg). Forum started by chakrapani gade
Kids
Kids Bed Styles
Baby
Baby Bedding
Soft and luxurious bed mattresses give your baby comfort and make him cheerful. Cartoon characters or fairy themes on ..
Bed Headboards
Bed headboards introduce a style statement in your sweet bedroom. They make your living more comfortable and lavish. T..
Bedding
Bedding Cover
Bedroom Decorating Ideas
Elegant bedroom décor may melt your all worries and tensions. Some simple but dazzling bedroom decoration or makeover ..
