Home -> Forums -> Construction -> Glossary -> 302 vs 304 grade steel for ralling
Thu Mar 19, 2015Total posts : 3
Topic: 302 vs 304 grade steel for ralling
i want to buy stair railing 304 grade steel but 302 also looks similar.as shopkeeper can give 302 with 304 rate.
Thu Mar 19, 2015Post  #1
Hi Paresh,
Its not 302, its 202 and 304 grades of steel.
304 is the best and rustproof but costly than the 202 grade.
On the other hand 202 is not rustproof but cheaper than the 304 grade.
202 can still be used to place not exposed to weather. It will give the same look.
Fri Mar 20, 2015Post  #2
Hi prakash ,
Is there any identification of product  to avoid cheating from shop keeper to gives us 202 instead of 304.
As both looks similar and we want 304  grade as it is going be used in exposed area
Fri Mar 20, 2015Post  #3
Buy it from a major vendor/shopkeeper or try to buy the material and have it done on Labour rate.
Glossary-Construction Questions (25)
2204
15524
2307
cement
Last answer on 8/25/2012 12:33:40 AM. by Ar. Manoj Ralen. Forum started by abhijeet joshi
2079
Modular Kitchen
Last answer on 7/3/2020 11:55:40 PM. by JAI PRAKASH. Forum started by paresh
6301
1718
2566
Interior Costing
Last answer on 7/11/2012 1:57:44 PM. Forum started by Bimlendra Jha
2939
1385
4312
2867
RCC Roof
13272
Marble Floor Comparison Required (Wonder Vs Katni Vs Dungri)
Last answer on 5/20/2014 12:04:53 AM. by Sunny Bansal. Forum started by Sunny Bansal
2844
Selection of Steel for home construction
Last answer on 2/18/2013 11:37:36 AM. by S L Gupta (Civil Engg). Forum started by sunny420
4922
COLUMN AND STEEL DESIGN
4922
4985
1755
Stair Grade Beam
Last answer on 3/30/2017 12:59:46 PM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen
11570
3430
Type of Cement
1827
Which elevator service company is the best for a residential place or semi commercial place?
Last answer on 1/5/2022 12:33:22 AM. by JAI PRAKASH. Forum started by Raghavendra Gudla
1535
The construction and infrastructure sector in India
Last answer on 3/5/2021 2:42:32 PM. by S L Gupta (Civil Engg). Forum started by thehunk
2157
5072
1787
Electricity LIne
Last answer on 5/7/2014 3:08:20 PM. by Ahmed. Forum started by Ahmed
1633
Construction cost of 7 years old house
Last answer on 8/19/2013 11:32:32 AM. by S L Gupta (Civil Engg). Forum started by Syed HazratHussain
Type
Types of Cement
HSD
Precautions
Steel
Steel Roofing
