Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> 9 Inch brick wall on 5 inch RCC roof
Sun Oct 16, 2016Total posts : 4
Vishal Thakur
Vishal Thakur
Topic: 9 Inch brick wall on 5 inch RCC roof
Hello All,
Constructed new house a year back.. open plot area 30ftx60ft = 1800sq fts (200 sq yards).
Here is my question..
On first floor engineer constructed 9 inch red brick wall on 5 inch RRC slab without laying column on ground floor as shown in diagram. please let me know is there an issue in future because of 9 inch wall load on slab? if yes then what is the solution for it.
our plan to add +2 floors in future.
Appreciate your quick response.
Thank you,
Vishal singh
Attachments: DSCN4905.JPG on Sun Oct 16, 2016,
floor plan G+3.jpg on Sun Oct 16, 2016,&n
Mon Oct 17, 2016Post  #1
Hello Vishal:
The image that you have posted shows many columns with interconnecting hanging beams. If the 9"thk wall is directly above one of these beams, then there is absolutely no issue in constructing it. Further floors can also be added by building over the existing walls on first floor.
I hope it helps.
-Abhishek Garg
Mon Oct 17, 2016Post  #2
Dear vishal
         There is any error in floor plan G +3 that is not opened for giving reference.
Mon Oct 17, 2016Post  #3
Vishal Thakur
Vishal Thakur
Thank you very much Abhishek and SL Gupta Ji to respond my query so quickly..
I understand if 9 inch wall construed directly above the beams there will be no issues.
but in my case 9 inch wall constructed on RCC 5-6 inch slab (centre) without laying beam. Please review the floor plan attached.
Vishal
Attachments: floor plan G+3.bmp Mon Oct 17, 2016,&n
Mon Oct 17, 2016Post  #4
Vishal Thakur
Vishal Thakur
There is an error with Floor plan not able to open attachment. So, i added photograph marked the area on which 9 inch wall build on top of slab without beam.
All center pillars has 20 mm TMT - 8 rods used. Corner/sides pillars has 16 mm - 8 rods used and all columns has 20 and 16 mm rods used respectively
please suggest.
Thanks again
Vishal Thakur
Attachments: DSCN4905.jpg Mon Oct 17, 2016,&n
4894
1950
1875
3574
2430
how to avoid rain water seepage in 4 inch brick wall any suggestion?
Last answer on 5/21/2015 5:29:55 PM. by JAI PRAKASH. Forum started by ashok
4430
3176
Sump construction
2861
walls
Last answer on 3/9/2021 5:57:05 PM. by S L Gupta (Civil Engg). Forum started by shabbir ali
3470
Cost of concrete walls
2256
Electrical Conduits
Last answer on 5/20/2014 1:25:16 PM. by ajaywahi. Forum started by ajaywahi
2025
I had constructed 4" inch wall on the external wall on the first floor what prec
Last answer on 6/26/2019 10:39:50 PM. by S L Gupta (Civil Engg). Forum started by Badhavath Rajeshwar
1543
Cement Slab as roof for elevation
Last answer on 3/8/2017 12:01:54 AM. by S L Gupta (Civil Engg). Forum started by Neel
3660
Foundation
3421
Cost of Brick Work
Last answer on 6/4/2014 3:43:02 PM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
1682
Hi, two questions i have.1) my door lengths are 78.6 and 79 inches .Flush door s
Last answer on 2/8/2017 2:32:54 PM. by S L Gupta (Civil Engg). Forum started by Manish Chugh
1366
1702
2211
2075
outside side wall with 4.5 inch width is suggested or not ? will it cause seepag
Last answer on 7/4/2020 2:24:25 AM. by JAI PRAKASH. Forum started by ashok
5811
3792
9885
2670
4628
4143
2865
5007
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
