Home -> Forums -> Construction -> Ground work -> 900 Sqft column required
Tue Jul 26, 2016Total posts : 1
Shivaraj
Shivaraj
Topic: 900 Sqft column required
Dear Experts,
I have 900 Sqft house build GF only nd how much column required in Ground Floor only plz advice me iam w8ing Your Reply
Thank you
Tue Jul 26, 2016Post  #1
Dear Sivaraj
         The numbers of column can be fixed according to plan and loading condition.The size of plan is required for column lay out.
3600
How we Calculate Construction Cost
Last answer on 10/21/2014 10:35:00 PM. by JAI PRAKASH. Forum started by JEETU KALANI
2865
18378
Hi ...Estimation of per sqft construction of a house on 900 sqft in Bangalore..Uttrahalliarea
Last answer on 6/20/2011 12:51:37 AM. by SUSHEEL. Forum started by arindam
1940
1871
1990
Residential complex
2004
if any have photos of best house plans with 900 sq.ft plse send it
Last answer on 7/27/2016 2:33:34 PM. by Beenu Phogat. Forum started by ram
2811
north seeing house 900 sq.ft house models
Last answer on 4/16/2012 2:06:19 PM. by Gunjan Utraja. Forum started by usha
we have 900 sq ft space want to build,kindly suggest for some map....vastu accor
Last answer on 6/23/2015 3:22:38 PM. by seema tyagi. Forum started by Raj
5213
2243
i want to make small duplex house in plot area (28x32)900 sqft build up area is
Last answer on 6/16/2015 4:35:43 AM. by JAI PRAKASH. Forum started by sudipta sinha
14650
Construction cost in Mysore 1200 sqft
Last answer on 5/27/2015 12:46:44 AM. by JAI PRAKASH. Forum started by Arun
6198
share plan for 900 sq ft... 22.5 x 40 (depth)
Last answer on 11/23/2015 1:57:34 AM. by JAI PRAKASH. Forum started by navneet
3164
I want to know the budget for constructing a house of 600sq.ft(G) and 900 sq.ft(
Last answer on 12/31/2020 2:22:31 AM. by narendra barde. Forum started by vidhya
2329
1603
Respected Sir,We are constructing a individual house at an area of approx 450sq
Last answer on 12/2/2016 11:53:14 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
1530
Last answer on 12/2/2016 11:43:21 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
2821
building a house
2995
8158
software
3899
2730
1833
lanterns
3133
false ceiling
2245
about construction
1786
4153
Cement Coba
3076
Water Harvesting System
1676
1757
water tank
2058
1760
1634
Pool construction cost
1993
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
