9" brickwork Compound wall length of 25ft and 7ft height with out beam / columns
Fri Aug 18, 2017Total posts : 1
Prakash
Prakash
Topic: 9" brickwork Compound wall length of 25ft and 7ft height with out beam / columns
9" brickwork Compound wall length of 25ft and 7ft height with out beam / columns. is it safe to construct? If yes, what should be the foundation shall be adopted.
Mon Aug 21, 2017Post  #1
         7feet high 9'' thick wall is unsafe, either construct 13.5'' thick wall or give Brick pillars 13.5x 13.5 feet at 10 feet interval and at the end with cement mortar ratio 1;4 with dust or any other coarse sand available in you area.
2539
1406
Roof of 250 sqft covering back yard
Last answer on 5/3/2016 12:32:09 AM. by JAI PRAKASH. Forum started by Raghu
2037
2708
2304
2034
2697
Last answer on 2/20/2014 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by HM12345
13774
overlap length to steel
2399
4903
How much it cost for laying a foundation for a 30x40 site upto 7ft deep and plin
Last answer on 5/4/2013 2:20:44 PM. by nithun. Forum started by nithun
1746
sir wall size to be constructed new is length 15'6" (in L-shape) and height is 1
Last answer on 8/20/2015 2:23:56 AM. by JAI PRAKASH. Forum started by Gunjan
2156
please give some suggestion, that we have onely4square feet land in the middle o
Last answer on 8/27/2012 3:33:59 PM. Forum started by Jagajothi
3941
1366
2559
4212
Selection of cement ..
1709
33 height 30 length
Last answer on 10/22/2016 11:52:32 AM. by Beenu Phogat. Forum started by nirmal
24
28
Centering
Canvas
Canvas Wall Art
