ABOUT ROD AND MORTAR USED IN THE ROOFING OF THE HOUSE
Sat Oct 10, 2015Total posts : 2
sumit
sumit
Topic: ABOUT ROD AND MORTAR USED IN THE ROOFING OF THE HOUSE
Q-1  HOW MUCH ROD IS REQUIRED IN THE CONSTRUCTION OF ROOFING ?
Q-2 WHICH TYPE OF ROD IS USED IN THE ROOFING OF THE HOUSE AND HOW MUCH?
Q-3 WHAT IS THE RATIO OF MORTAR USED IN THE ROOFING ?
Sun Oct 11, 2015Post  #1
A-1 = Depends upon the size and the plan and number of beams used.
A-2 = Use any brand e.g TATA, Rathi Kamdhenu, Jindal etc
A-3 = 4:2:1
Mon Oct 12, 2015Post  #2
Dear Sumit
            1. The MS Steel bars are used in roof slab is according to loading condition. However in roof slab the quantity of MS Steel bars is 2.5 kg per cft of cement concrete or .8 to .9 kg per sft area of roof slab.
2. use MS Steel bars of any standard mill.
3. In general cement concrete ratio is 1;2;4 but now a days the ratio must be 1;1.5; 3.is used for taking in view the Earth Quack safety.
roofing
Last answer on 10/14/2015 3:25:36 AM. by JAI PRAKASH. Forum started by sumit
1894
1666
Last answer on 7/3/2020 11:11:05 PM. by Navneet Jharia. Forum started by Sandeep
3272
Roof Concrete Strength
2874
cost of rcc slab
Last answer on 12/26/2013 11:30:08 AM. by S L Gupta (Civil Engg). Forum started by abdul wahid laskar
3734
sir I have built a residential house , I want plain ceiling roof casting for 12o
Last answer on 2/4/2022 4:13:31 AM. by Bentaev. Forum started by Kailash Sahoo
2823
2501
1344
Bending of rods used in pillars
Last answer on 10/17/2016 12:27:56 PM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
1699
TMT rod to be used for the structure
Last answer on 10/3/2015 11:39:32 AM. by S L Gupta (Civil Engg). Forum started by nhrajesh
1453
I wish to construct a single story house using bricks and RCC roofing. Pl advise
Last answer on 7/20/2015 7:24:43 PM. by JAI PRAKASH. Forum started by r.n.misra
2289
slab
Last answer on 12/20/2021 5:13:48 AM. by ringwang. Forum started by ringwang
1969
water dampness
Last answer on 11/13/2014 6:26:53 PM. by JAI PRAKASH. Forum started by sunder
2316
Plz guide us about no of floor we can contruct
Last answer on 4/3/2011 5:04:24 PM. by S L Gupta (Civil Engg). Forum started by Bhaskar
1979
Last answer on 10/13/2016 11:06:46 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
4128
1738
weather proof repair reg
2588
mortar thickness in brick joints in foundation
Last answer on 8/23/2011 8:47:15 PM. by S L Gupta (Civil Engg). Forum started by ahsan
1548
Insulating roof using used cement bags
Last answer on 3/26/2015 1:35:41 AM. by JAI PRAKASH. Forum started by Arvind Bhaskar
Skylight
Cooper
Hard
