Home -> Forums -> Construction -> Start Construction -> About Cement
About Cement
Sun Feb 02, 2014Total posts : 1
AAYUSH
AAYUSH
Topic: About Cement
I want to know OPC cement is Better OR PPC ?
Please mail your ideas about the quarry on my mail id:
"aayush.agarwal399@gmail.com".
I'll be waiting for your comments.
Thank You!! :)
Mon Feb 03, 2014Post  #1
Dear Aayush
        OPC CEMENT is better than PPC CEMENT
http://www.gharexpert.com/articles/Cement-1470/Types-Cement_0.aspx
3791
4211
Selection of cement ..
1923
2409
what are these 3 types
2695
1766
1460
1659
Last answer on 7/15/2017 12:48:17 AM. by S L Gupta (Civil Engg). Forum started by Frank lun ngaihte
3074
1741
3992
1785
1876
Last answer on 11/3/2016 10:40:18 AM. by S L Gupta (Civil Engg). Forum started by shashi
2967
Tips for Cement Paint
2693
cement plastering
2081
Last answer on 10/23/2010 3:33:17 PM. Forum started by sandeep Dholakia
2276
2119
Difference b/w company and factory manifectured cement
Last answer on 2/22/2013 11:30:32 AM. by S L Gupta (Civil Engg). Forum started by paresh
7005
3272
For Estimate
3310
Types of Cement
White
White Cement
You can boost up architectural beauty of your home using white cement since the strength of building and its component..
Checklist for Cement Plaster
Buying
Buying tips for Cement
Gray
Gray Cement
Do you know the strength of a building depends on the quality of cement? Cement/ Gray cement is one of the most import..
