Home -> Forums -> Construction -> Foundation -> Absence of Plinth Beam
Sat Oct 29, 2016Total posts : 2
Pritam Thakur
Pritam Thakur
Topic: Absence of Plinth Beam
I am constructing a G+VI residential building. My engineer has provided the structural drawing which has a raised plinth (around 1m above ground level) and Deep Pile Foundation. There is only one beam, that is above the Pile-Caps. Above those tie-beams, the columns goes upto a height of around 4.5 metres till the beams of the ground floor floor roof. The height of the ground floor is 3 m, and 1.5 m below is filled with silver sand from top of Pile-Caps. There is no beam at the plinth level.  Will there be any issue with the absence of plinth beams in this case?
Also, how high can the columns be given the dimensions vary from 300x500mm to 300x600mm.
Attachments: pic1.jpg on Sat Oct 29, 2016,
pic2.jpeg on Sat Oct 29, 2016,
pic3.jpeg on Sat Oct 29, 2016,&n
Sat Oct 29, 2016Post  #1
Er.S.K.Jain
Er.S.K.Jain
If the column is design for 4.5 meter height it is safe. Any height of column is possible to design as long column. normally we will take up to 12 to 15 times of column width but it is not limited to it.
Plinth beam required if you need to place any wall from plinth other wise o.k.
But as per earthquake resistance it is required to design long column very carefully.
its better to provide a lintel on plinth level as per earthquake resistance guide line.
Sat Oct 29, 2016Post  #2
Pritam Thakur
Pritam Thakur
Hello Sir,
Thank you very much for the answer.
In this case the engineer has started the wall from the beams at NGL, and gone upto the first floor roof. So the height of the wall is around 4.5m, 0.5m being below ground, 1m at Plinth, and 3m height of the ground floor.
4665
Regarding Beam
9196
3883
stone foundation
5692
2279
Plumbing works
14600
3129
Plinth beam at ground level
2017
4666
RCC beam over plinth beam
Last answer on 7/3/2020 10:34:03 PM. by S L Gupta (Civil Engg). Forum started by rajeev
1469
what is the solution in absence of southwest corner to home?
Last answer on 5/3/2016 11:24:35 PM. by JAI PRAKASH. Forum started by sharad
13853
Pillar & plinth beam frame work avoiding stone foundation
Last answer on 5/11/2017 11:22:09 AM. by S L Gupta (Civil Engg). Forum started by tp_bangalore
3459
What is gap to maintain in Plinth/beam/Pillar/roof/Chejja
Last answer on 11/10/2016 5:26:49 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
1869
Can anyone suggest the breakup ratio percentage cost like up to plinth beam, up
Last answer on 1/2/2021 5:27:29 AM. by S L Gupta (Civil Engg). Forum started by Shaik ibrahim
10048
3657
2995
6530
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1991
Construction Agreement
3090
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Centering
Dining
Dining Room Ceiling
Through
