Home -> Forums -> Construction -> Start Construction -> Actual cost difference between Precast RCC channel roofing and RCC slab roofing
Thu Mar 07, 2013Total posts : 3
Satya
Satya
Topic: Actual cost difference between Precast RCC channel roofing and RCC slab roofing
Is there any cost saving achieved if pre-cast RCC roof channels are used in lieu of traditional RCC slab in roof construction? Research papers talk a lot about savings but practically what is the scene in India?
Wed Apr 30, 2014Post  #1
Nishikant Pathak
Nishikant Pathak
Post subject: Precast Slab & Conventional Slab
Dear Satya,
The Precast slab laying is quick, there is much time saving. In conventional RCC slab shuttering material is stuck for 28 days. This makes it cost efective. But care should be taken while filling the grooves of Precast slab. The Precast slab is laid in parts, so goove filling is important. Waterproofing material should be used for that. Now adays, screeding of 40mm is done above roof slab to avoid leakage.
In terms of material, actualy there is no saving, it's saving in terms of minimum wastage of steel.
Fri Dec 16, 2016Post  #2
Pranav
Pranav
           Can we replace  spalling RCC  slab with RCC precast slab in the house having no column.
How will it affect the cost of construction compare to traditional slab construction?
Sat Dec 17, 2016Post  #3
Dear Parnab,
              In my view you should lay traditional RCC slab no much difference in cost.
9893
3752
191898
3979
Roof leakage
4647
1875
2254
Hello members..i am building a small bungalow in Karjat .Mumbai.. and would like
Last answer on 1/27/2015 7:22:56 PM. by JAI PRAKASH. Forum started by FRANCO VAZ
3964
cost estimater
3234
Ferrocement channels roofing Vs Rcc slab
Last answer on 9/15/2021 9:04:11 PM. by S L Gupta (Civil Engg). Forum started by Sameer S Pawade
3087
6379
kota Stone Roofing
3802
2991
6411
RCC Roofing Cost
Last answer on 12/11/2013 11:01:19 AM. by S L Gupta (Civil Engg). Forum started by Praveen Srivastava
2032
2611
Last answer on 5/26/2016 10:55:05 AM. by S L Gupta (Civil Engg). Forum started by Madhu Ranjan
3310
2059
Cooper
