Cement Plastering
Wed Dec 23, 2015
Prasad
Topic: Advantage/disadvantage of Gypsum plastering and procedure to apply
We have seen in our apartment that the builders use gypsum paste for finishing of internal wall plastering and it's done in the following method:
1. Plastering of the RCC wall with cement+sand+mortar dust mixture.
2. Applying a Gypsum coat over it immediately after plastering has finished i.e. on the same day.
My question is :
1. Is the above method proper or there are any guideline for Gypsum plaster finishing?.
2. Will the Gypsum coat affect curing of internal cement+sand plastering as both have been done at the same time.
Thanks,
Prasad
Thu Dec 24, 2015
Should be applied when the plaster is 100% dry.
Thu Dec 24, 2015
Prasad
Hi Jai Prakash,
Thanks for the information.
Does it mean in general that approximately after 24 hrs of plastering?
And how it affects the curing time i.e. do we have to put water more frequently for curing for more days?
Prasad
Sat Dec 26, 2015
At least after 7-10 days of plaster with proper curing.
Fri Jan 01, 2016
Post #4
Prasad
Thanks for the information you have provided.
8879
Last answer on 1/21/2021 1:04:07 AM. by
karthik
Rahul
7925
Last answer on 12/26/2015 7:44:40 PM. by
prasad K
2003
we are planning to construct marriage functional hall in 3 acre what is the proc
Last answer on 10/17/2016 12:19:06 PM. by
swapna
1702
Last answer on 7/3/2020 11:20:06 PM. by
PCR.Manohar
18029
What are the advantage and disadvantages of FLYASH BRICKS?
Last answer on 10/18/2014 4:07:06 AM. by
gganesan
3928
Last answer on 7/28/2015 11:31:41 PM. by
nithin
2713
Kids room ceiling designs
Last answer on 7/12/2011 11:54:47 PM. by
yashwant
indraneel basu
2436
Gypsum Plaster Vs S/C Plaster
Last answer on 5/27/2015 11:10:51 AM. by
Tarun
4348
rate comparison
Last answer on 7/4/2020 2:15:33 AM. by
aammiitt
aammiitt
1717
marriage function hall
Last answer on 11/3/2016 10:46:33 AM. by
swapna
4135
False ceiling
Last answer on 1/2/2021 5:27:47 AM. by
kumar.x123
2567
Which are advantages and disadvantages of POP?
Last answer on 9/27/2009 5:08:03 PM. by
nkj
3144
What are advantages and disadvantages of iron doors?
Last answer on 1/30/2010 9:20:41 AM. by
rajesh malik
13271
What is the advantage and disadvantage of using Robo Sand (stone crush) in RCC a
Last answer on 10/17/2014 9:27:21 AM. by
Ajith Prakash
3492
Last answer on 7/3/2020 9:53:22 PM. by
Modern Homes
1933
Advantages and disadvantages of Steel doors and windows?
Last answer on 11/24/2016 12:19:49 PM. by
1542
POP OR GYPSUM
Last answer on 10/25/2016 6:30:29 PM. Forum started by
shreenivas
2533
l would like to see more gypsum designs
Last answer on 1/14/2022 3:20:41 AM. by
salome kapanga
3009
Last answer on 6/26/2019 10:25:56 PM. by
kalpana
2929
Plaster
Last answer on 2/26/2022 12:51:12 AM. by
Plaster work
Last answer on 2/15/2022 8:09:55 AM. by
AleksShamles
Alok Das
3046
Plastering
Last answer on 2/15/2022 7:34:36 AM. by
vijay
fransisco_143
1924
Last answer on 11/19/2021 8:52:08 AM. Forum started by
aozzoa
2003
PPC and OPC cement
Last answer on 11/15/2020 4:39:17 AM. by
Meda Kameswara Rao
11298
Last answer on 10/3/2020 5:12:40 AM. by
Swapnali
sira
1870
suggest for exterior
Last answer on 7/1/2019 12:57:37 AM. by
Gaurav
7004
Last answer on 11/8/2017 2:30:27 AM. by
Rajesh
9157
Last answer on 8/20/2016 12:41:02 PM. by
Mohan
1876
OPC and PPC cement
Last answer on 6/25/2016 11:11:46 AM. by
Meda Kameswara Rao
2011
coarse aggregate
Last answer on 8/10/2015 4:00:45 PM. by
satinder parshad
satinder parshad
1826
Nice
Last answer on 7/3/2015 3:50:34 AM. by
richd2
2436
Tarun
2173
Outer Plaster
Last answer on 2/27/2015 11:33:21 AM. by
Last answer on 5/19/2014 12:07:41 PM. by
sanjeev kumar
2734
putty work on walls
Last answer on 1/6/2014 11:38:34 AM. by
john
2236
Last answer on 12/19/2013 10:54:10 AM. by
MOHD WAKEEL
MOHD WAKEEL
2826
Last answer on 9/24/2013 6:12:09 PM. by
A.Venki
George Kattapuram
2032
Last answer on 7/2/2013 11:01:20 AM. by
rajesh700046verma@yahoo.co.uk
POP expands very slightly on setting.
Tips for Aluminum Paint
Aluminum paint produces fine look, lustrous and superior quality finish on metal and wood. It is tremendously resistant
Checklist for Cement Plaster
What are the advantages and disadvantages of plastic/PVC doors?
Plastic Doors-Termite proof ,tough and durable ,anti corrosive ............
