Fri Mar 01, 2013 | Post #1 | S L Gupta (Civil Engg)
In my view the alternative have not much effect on cost. For RCC slab do not use Portland Pozzolana cement use 43 grade Portland cement with river sand or stone dust but one thing also clear that the sand should not have silt more than 4%. Wash the sand before use. | |
Fri Mar 01, 2013 | Post #2 | akmurty1
Join date: Sep 2012 | u can safely use them for components other than RCC | |
Mon Mar 04, 2013 | Post #3 | nasad
Join date: Feb 2013 | Post subject: Advice on use of Portland Pozzolana Cement and G...
@SL Gupta and @akmurty1,
Thanks a lot for the valuable advice.
If commercially available PPC (with ISI specs) is used in Mortar along with Granite Dust for walls and plastering, is there any need for adding any Resin to the mix, to prevent cracking? If yes, could you please suggest an appropriate Resin and the ratio of Resin by volume?
Thanks | |
Mon Mar 04, 2013 | Post #5 | nasad
@ S L Gupta. Thanks a lot Sir.
nasad
Green Building-Construction Questions (38) | |
