Home -> Forums -> Construction -> Fine Sand -> Alternate for River Sand
Sun Feb 24, 2013Total posts : 2
RENJI
RENJI
Topic: Alternate for River Sand
Can we use Msand(stone dust) for plastering work. Msand or riversand which one is better for plastering works.
Mon Feb 25, 2013Post  #1
Dear Renji
Stone dust is equally good for plaster, if it had more silt than wash the sand before use. See the website gharexpert.com construction section Raw material where you will find lot of articles about construction. See the link below
http://www.gharexpert.com/articles/Fine-Sand-894/Fine-Sand-classification-sand_0.aspx
Mon Feb 25, 2013Post  #2
RENJI
RENJI
Post subject: Curing period
Dear Gupta,
Curing time for both Msand and River sand is same or not.
Can we use curing compound insted of watercuring as water is scarce now a days.What is the ratio of mixing curing compound and the approximate cost and the good brand of curing compound.
Renji
Fine Sand-Construction Questions (27)
3681
2210
sand alternate for concrete
1746
1441
2080
river sand
2727
6429
2990
M-Sand for Plastering
16056
robo sand vs natural sand
2648
3480
Robo Sand for Brickwork
7199
Alternative to river sand for wall plastering jobs
Last answer on 1/7/2011 3:36:01 PM. by jaydeep. Forum started by S. Krishnamoorthy
3033
3512
alternative for river sand
Last answer on 6/11/2011 9:17:04 AM. by S L Gupta (Civil Engg). Forum started by sudakar
3214
Would like to know is it correct to use the M.Sand instead of river sand for the
Last answer on 10/30/2010 2:10:01 PM. by S L Gupta (Civil Engg). Forum started by kcantony
2659
3599
Can we use crushed Sand for house construction
Last answer on 4/8/2014 12:28:09 PM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
1992
coarse aggregate
2088
joinery work
Last answer on 4/26/2011 9:58:00 PM. Forum started by suresh
2180
2287
Sand units
1673
Sand units
1508
Sand units
2990
16056
2799
sand wight per cu.feet
Last answer on 11/5/2012 11:47:35 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3512
Swimming
Swimming Pool Filters
Through
How To Repair Cracks
