Home -> Forums -> Construction -> Raw Material -> Alternative materials for Modular Kitchen
Wed May 22, 2013Total posts : 3
GULSHAN RAI GULATI
GULSHAN RAI GULATI
Topic: Alternative materials for Modular Kitchen
Dear Fellow members , kindly suggest the best  option based on practical experiences , from the given below options, keeping in view their durability , workability , cost and appearance factors, in highly TERMITE infected area instead of widely used wood & plywood for the construction of modular kitchen  :
Use of Aluminium powder / polyester coated frame members infilled with Prelaminated  Particle board in  cabinate shutters , drawers , partitions
OR
Use of Rubber wood frame members for  cabinate shutters , drawers , partitions infilled with Prelaminated Particle boards,
OR
Any other combination of better & readily available materials , in Delhi / Gurgaon City, shall be highly appreciable.
Thu May 23, 2013Post  #1
Dear Gulati
            The first option of using Aluminum frame with laminated particle board or glass in cabinet shutter etc is better than other option in the kitchen.
Fri May 24, 2013Post  #2
GULSHAN RAI GULATI
GULSHAN RAI GULATI
Dear Gupta g,
Thanks for the valuable suggestions .
Gulati.
Sat Jul 27, 2013Post  #3
Pooja
Pooja
Post subject: Modular Kitchen Material
Dear Mr Gulati
You can also use polyester coated frame members infilled with Prelaminated  Particle board in  cabinate shutters.
8126
Modern Kitchen
Last answer on 2/19/2022 3:13:17 AM. by Gohkadd. Forum started by ankita
3925
Kitchen Cabinets
Last answer on 7/3/2020 9:37:52 PM. by leelindsey. Forum started by madhuri
4267
any gud designer for modular kitchens in bangalore
Last answer on 7/4/2020 2:23:27 AM. by Dinesh Mittal. Forum started by pv rao
3644
Last answer on 10/11/2020 7:16:16 AM. by Amit Hasija. Forum started by disha gupta
3212
modular kitchen photo or bed design
Last answer on 7/4/2020 4:23:39 AM. by S L Gupta (Civil Engg). Forum started by sanjay
3285
Kitchen modular size 8*8 fit
Last answer on 10/11/2020 7:13:57 AM. by JAI PRAKASH. Forum started by Hitendra singh bhadoria
2113
Last answer on 1/27/2015 7:29:54 PM. by JAI PRAKASH. Forum started by Hitendra singh bhadoria
2858
modular kitchen
Last answer on 2/23/2022 4:38:18 PM. by JAI PRAKASH. Forum started by Anu
1873
Hettich Modular Kitchen in 800/Sq.Ft. only
Last answer on 11/12/2021 12:02:44 AM. by S L Gupta (Civil Engg). Forum started by JAI PRAKASH
7232
2 lakh litre water tank
4182
hi,i have a very small kitchen want to change into a modular kitchen can you sug
Last answer on 10/11/2020 7:17:40 AM. by Amit Hasija. Forum started by Rima_M
3110
my kitchen is of 9 by 10 size. I want L shape modular kitchen with serving count
Last answer on 1/28/2021 10:34:37 PM. Forum started by suman
3739
Hi Now I am in the construction, my kitchen is 10 feet x 10 feet, your expert is
Last answer on 8/1/2018 11:35:24 PM. by S L Gupta (Civil Engg). Forum started by kannaa
7310
Modular Kitchen
Last answer on 11/30/2021 12:56:09 AM. by axelbach. Forum started by Veena Gil
1538
6392
Wooden Modular Kitchen versus Stainless Steel modular kitchen
Last answer on 7/3/2020 10:10:51 PM. by S L Gupta (Civil Engg). Forum started by Meenakshi
2911
Last answer on 1/21/2022 6:49:43 PM. by JAI PRAKASH. Forum started by Suveera
2177
hello,i want d designs of modular kitchen of area 9'6"*10'6"....
Last answer on 12/31/2020 2:19:10 AM. by Priti Arora. Forum started by priyanka
3563
Kitchen Pictures
Last answer on 8/28/2020 2:40:10 AM. by Swati Ray. Forum started by SUTANU RANA
3075
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11104
2189
2037
Estimate
11123
3073
Steel
3039
use of tmt bar
1643
work turned out by labour
2457
estimate
1762
2992
3606
1943
Cost of Steel construction
1613
2136
READY MIX PLASTER
1865
2223
zero slump concrete
Modular
Modular
Modular Office Furniture - Versatile for your Office
Having the right office furniture is very important to make office environment comfortable and as productive as possib..
Kitchen Accessories
Kitchen Remodeling Ideas
Kitchen Backsplash
Kitchen Cabinets
Small
Small Space Kitchen
Kitchen design mistakes
