Thu Feb 28, 2019Total posts : 1
Anu Mohan
Anu Mohan
Topic: Alternatives of Steel reinforcement like Basalt reinforcement bars, what are the
Alternatives of Steel reinforcement like Basalt reinforcement bars, what are the possibilities of it being accepted for construction in current Indian scenario.
Thu Feb 28, 2019Post  #1
Basalt Rebar reinforcement is an alternative to steel and fiberglass for reinforcing concrete
Made from volcanic rock basalt rebar is tough, stronger than steel and has a higher tensile strength.
Much lighter than steel, 89% percent in fact! One man can easily lift a 100 meter / 328 foot coil of 10 mm basalt rebar.
Basalt rebar is naturally resistant to alkali, rust and acids. Moisture penetration from concrete does not spall. Needs no special coating like fiberglass rods.
Basalt rebar has the same thermal coefficient expansion as concrete!
Allowing thinner, lighter panels and decks, basalt rebar reduces the thickness and spacing between the rods and the concrete and surface. Much more flexible design! Smaller rods allow for more critical spacing and designs.
Basalt rebar is easily cut to length with regular tools.
Basalt rebar does not conduct electricity or induce fields when exposed to RF energy, great for MRI or data buildings.
Basalt rebar is perfect for Marine enviroments and Chemical plants where corrosion is a continuous concern.
1502
1255
2562
Specification of ‘Plastering’
2898
RCC Roof
2376
6470
1507
TORSION REINFORCEMENT
Last answer on 4/15/2016 2:02:52 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1193
How do Engineers calculate the Reinforcement needed for house. Is it possible to
Last answer on 9/25/2018 11:57:50 PM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
1632
1304
3272
Roof Concrete Strength
3059
steel formula
Last answer on 4/16/2014 8:05:15 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
13772
overlap length to steel
1393
1657
1188
Hi, Is there any cost effective methods to hire bending machines for reinforceme
Last answer on 7/4/2020 4:22:17 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
2244
1509
17
Type
HSD
TMT
Precautions
Dining
Dining Chairs and Bar Stools
