Home -> Forums -> Interior -> Bathroom Ventilation -> Aluminium window misfit. need correction
Mon May 16, 2016Total posts : 1
Vishesh
Vishesh
Topic: Aluminium window misfit. need correction
Hi Team,
we ordered a aluminium window however the size does not fit the space. The person has fixed the window on the inside of the bathroom while leaving lot of space between window frame and outside steel frame. According to him the window size cannot be changed and it will remain as is. Pls help with a solution.
Tue May 17, 2016Post  #1
Dear Vishesh
             It is not possible to comment without drawing. In my view to take help from any architect/ interior designer/ civil engineer of your city who can better in position to give any idea to beautify the said window.
Bathroom Ventilation-Interior Questions (24)
2738
i need.s windows aluminium with gllas & fire doors pvc construction in india l
Last answer on 2/24/2022 1:02:52 AM. Forum started by muhammad mansoor
2731
3052
which windows are better for goa wooden or aluminum sliding
Last answer on 5/30/2013 11:04:45 AM. by S L Gupta (Civil Engg). Forum started by oscar
2048
PVC windows
1867
Precautions during Fabrication and Fixing of Window Grill.
Last answer on 9/5/2014 8:02:17 PM. by JAI PRAKASH. Forum started by subir
2423
What are various materials used for windows?
Last answer on 5/14/2014 1:56:15 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
1865
for windows with a/c provision, can we use aluminum frame? is it safe and strong
Last answer on 2/23/2011 10:58:58 AM. by Mohini Sharma. Forum started by sunita
2181
Comparing uPVC Windows with Wooden Windows and Aluminium Windows
Last answer on 9/11/2010 11:27:22 PM. by sachin. Forum started by Mahendra Agarwal
2209
i need some dome designs for mosque in acrylic sheet with angle frame or alumini
Last answer on 10/5/2010 10:56:37 PM. by . Forum started by aslam
5226
2130
Last answer on 1/16/2022 11:07:26 PM. Forum started by Aly Atif
2634
need to see some designs for window ralings
Last answer on 1/20/2022 2:24:15 AM. Forum started by nick shetty
2326
My husband wants to furnish the doors and windows completely with teak wood..but
Last answer on 8/5/2011 11:12:02 AM. Forum started by sangeetha
2447
1433
i want to change some correction in our map. 40x30 sqft construction east facein
Last answer on 8/9/2017 12:10:04 AM. by S L Gupta (Civil Engg). Forum started by atul pandey
1382
I want to know my house vastu is correct or I'll have to do some corrections in
Last answer on 9/17/2017 10:46:48 PM. by S L Gupta (Civil Engg). Forum started by Devidas Gund
6604
Which chokhat is best wood or iron press or aluminium
Last answer on 8/20/2018 12:28:42 AM. by S L Gupta (Civil Engg). Forum started by Shivam gupta
2185
2606
Window position on wall
1863
v good colur combination
Last answer on 7/3/2020 10:42:46 PM. Forum started by gautam
1397
Heat recovery ventilation
Last answer on 7/3/2020 10:38:03 PM. Forum started by m z a siddiqui
1611
Last answer on 7/3/2020 10:37:05 PM. Forum started by m z a siddiqui
2138
Bathroom Ventilation System
Last answer on 7/3/2020 10:35:32 PM. by leelindsey. Forum started by Partha Sarkar
2514
Last answer on 6/20/2009 11:58:07 AM. by naresh kumawat. Forum started by Shivani Bahl
Aluminum
Aluminum Roof
Tips for Aluminum Paint
Aluminum paint produces fine look, lustrous and superior quality finish on metal and wood. It is tremendously resistant
Aluminum
Aluminum door finishes types
There are variety of options for aluminum door finishes available. Let’s get to know the types and recommendation for..
What are the advantages and disadvantages of Aluminium doors?
ADVANTAGES:Strength, stability, weatherproof qualities. DISADVANTAGES: Quick oxidation, easily water stained...
Aluminium
Aluminium doors
Are you looking for a strong door for your home? Aluminum door is right choice for initial security of your room. Thes..
Why
Proper
