Home -> Forums -> Construction -> Paints More -> Applying wall putty after plastering
Sun Feb 12, 2017Total posts : 2
Rahul
Rahul
Topic: Applying wall putty after plastering
How many days(minimum) after plastering wall, apply putty?
Mon Feb 13, 2017Post  #1
karthik
karthik
A minimum of 7 days curing is required if you have done cement plaster.
If you have time, you can delay the application of putty by a bit more so that there will be no shrinkage cracks later because of improper (lack of) curing. If there are any cracks also that appear in this period, it can be filled with wall putty.
Mon Feb 13, 2017Post  #2
karthik
karthik
If you have done gypsum plaster, No curing is required and putty can be applied after 48-72 hours
Paints More-Construction Questions (26)
4626
time for paint and wall putty
2518
2212
Painting interior walls
2228
putty coating
Last answer on 7/3/2020 11:10:29 PM. by S L Gupta (Civil Engg). Forum started by K Umapathi
2715
wall putty
Last answer on 1/2/2021 5:22:50 AM. by leelindsey. Forum started by paresh
536
3283
Wall Putty on exterior wall
9539
Wall Putty and primer
Electrical fitting - Switches and sockets
Last answer on 12/12/2012 1:07:05 PM. by Vijay. Forum started by Vijay
3083
2924
7005
2991
Wall Putty ,primer and paint
4502
3992
3841
3380
Recurring Cracks
2350
Need Suggestion
2186
Exterior wall putty
Last answer on 1/17/2014 11:53:01 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2411
Very useful Website for all the Professionals whoever involved in Construction F
Last answer on 12/31/2020 2:29:49 AM. by Gunjan Utraja. Forum started by suresh
2177
Painting old house
Last answer on 1/24/2017 12:52:24 PM. by S L Gupta (Civil Engg). Forum started by soumyabrata
1824
wall primer
Last answer on 1/10/2016 9:04:01 PM. by JAI PRAKASH. Forum started by Anu
1891
Wall Putty
Last answer on 3/11/2014 2:11:56 PM. by Abhishek Garg (Builder & Engineer). Forum started by Purvi Panchal
2186
Exterior wall putty
2086
WHAT IS THE COSTING OF VNYLE FLOORING PER SQ FEET.
Last answer on 7/27/2012 1:05:42 PM. by S L Gupta (Civil Engg). Forum started by mksharma
1779
Place to buy cheap paints
Last answer on 10/29/2011 6:35:31 AM. Forum started by judyparker
Plastering
Plastering
Checklist for Cement Plaster
Gypsum
Specification of ‘Plastering’
How to clean plaster ceiling?
Canvas
Canvas Wall Art
