Home -> Forums -> Construction -> Start Construction -> Architectural plans For Residential projects
Tue Sep 02, 2014Total posts : 2
khurshid
khurshid
Topic: Architectural plans For Residential projects
Please suggest a plan of Plot Width: 45 Feet Plot Depth: 12 Feet
of floors 1. containing 3 bedroom 1 kitchen 2 bathroom and staircase also.
Tue Sep 02, 2014Post  #1
anand
anand
please send your site plan
at anandshahconsultant@gmail.com
Thu Sep 04, 2014Post  #2
Post subject: gharexpert services
After
completion
of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
Thanks.
2882
Help with a documentary about sustainability
Last answer on 10/5/2021 8:27:02 AM. by S L Gupta (Civil Engg). Forum started by Chibi Moku
2463
east facing residential house plan for double bed room with vastu required
Last answer on 5/5/2016 2:14:48 PM. by Anany goel. Forum started by SatheeshB
2113
Want to build 30*35 residential building suggest me some plans
Last answer on 1/5/2022 12:37:08 AM. by sweety. Forum started by ihsan
1955
Dear All,I am planning to build house(25X30) in Mysore, can any one suggest engg
Last answer on 10/5/2015 6:55:47 PM. by JAI PRAKASH. Forum started by M K Prem Kumar
5385
Last answer on 7/3/2020 9:15:14 PM. by S L Gupta (Civil Engg). Forum started by kcp
2288
i need house plan for 23*47feet east view
Last answer on 12/4/2014 12:51:39 AM. by JAI PRAKASH. Forum started by kuldeep1
3529
Contruction Tool
1909
construction cost
Last answer on 1/31/2022 4:30:31 AM. Forum started by Roogwed adep
2110
2547
Last answer on 3/2/2015 12:09:44 PM. by seema tyagi. Forum started by Alok
2525
i am draughtsman i want to lern basic idea about the architectural layout and st
Last answer on 1/13/2022 12:08:40 AM. by suheb alam. Forum started by faysal mehmood
4163
GLASS BLOCKS / BRICKS
3386
Architectural Plan
Last answer on 5/22/2021 4:13:47 PM. by viveik. Forum started by Partha Sarkar
1479
I would like to go through some energy efficient architectural plans for a house
Last answer on 9/21/2011 10:58:47 PM. by S L Gupta (Civil Engg). Forum started by Rajata Roy
1845
I'm Working at a govt. approved Project
Last answer on 1/7/2011 6:57:12 PM. by S L Gupta (Civil Engg). Forum started by sanjeev pradhan
2279
vastu for industrial project
Last answer on 7/19/2010 7:09:38 PM. by sabina vanjani. Forum started by harbans singh sekhon
2209
how to calculate plumbing material for any project
Last answer on 10/5/2014 11:19:25 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
1861
I want knowledge about commercial interior project...is there any refreance like
Last answer on 8/5/2015 4:39:43 AM. by JAI PRAKASH. Forum started by sandeep yadav
1543
2451
3274
3285
4429
3975
2197
2699
4210
5168
2378
2294
1996
2447
2114
3195
2047
12514
2164
2010
2726
Architectural
Architectural Shingles
If it is time to replace your roofing, ask about architectural shingles.Laminate shinglesor architectural shingles are..
