Thu Aug 04, 2011Total posts : 1
BEN
BEN
Topic: BRICK ROOF SLABIS IT POSSIBLE TO CONSTRUCT A BRICK ROOF SLAB???MAKING THE BRICKS
BRICK ROOF SLABIS IT POSSIBLE TO CONSTRUCT A BRICK ROOF SLAB???MAKING THE BRICKS INDULGE INSIDE THE ROOFS. NOT AS A DECORATIVE, IT SHOULD CARRY THE LOAD...
Thu Aug 04, 2011Post  #1
Dear Ben
     Your point is not much clear. If you  want reinforced brick concrete slab, than the procedure is as below.
Lay the miled steel bars @ 12'' center to center and place 3nos first class bricks jointed with cement mortar 1;4 in 12'' square than fill rest of the space with cement cocrete with top cover by 25 mm cement concrete after curing remove the shuttering and under side should be plastered.
6286
brick tile tracing
Last answer on 7/4/2020 2:14:39 AM. by S L Gupta (Civil Engg). Forum started by rahul
1067
4179
GLASS BLOCKS / BRICKS
9196
1875
2992
2025
3980
Roof leakage
2417
2873
FLYASH OR CLAY BRICK
2707
type of brick
3456
2350
3928
12252
191901
15
17
Brick Arches
Specification of Brick
Bricks Quality
Buying tips for Bricks
