Home -> Forums -> Construction -> Start Construction -> BUILDING MATERIAL RATES & PETTY JOB RATES
Fri May 10, 2013Total posts : 2
GULSHAN RAI GULATI
GULSHAN RAI GULATI
Topic: BUILDING MATERIAL RATES & PETTY JOB RATES
Dear Ghar Expert Team.
Let me first appreciate for the creation of On-line information library related to almost all aspects of building / house construction activities beneficial to every common man.
It's a very useful and informative platform for getting all relevant guidance , solution and resolution of building construction , addition , alteration , modification problems.
I would like to add here that , in addition to available data and services, certain more information listed below , if  made available , than most common problem about the cost / price of the materials and services, requiring during and after construction work  ,will relieve the tension of cost escalation matter.
[A]. To give the idea of prevailing  market rates of most common building materials like Bricks , Cements , Aggregates , Sands , Steel bars , Timbers , Door shutters , Flooring Materials , Finishing Materials  , Plumbing , Sanitary , Electrical , Air-conditioning , Horticulture , Gardening , Safety & Security works.[Based on the standard make of materials being used and available with established dealers in the locality].
[B] To give the idea of prevailing labour rate for new building construction works.[ Based on the rates and specifications being charged by the contractor , which are under construction at the time of data collection]
[C] To give the idea of labour plus material rates for new building construction rates [ Based on the rates and specifications being charged by the contractor , which are under construction at the time of data collection] .
[D] To give the idea about the rates of various services being offered by the registered architects linked to residential and other building construction works in the approved localities.
I hope the above initiation , if considered , shall help to make this established site a sought after by one and all , since NO other points are left out for the common man to search out  elsewhere for the building construction activities.
Mon May 13, 2013Post  #1
Dear Gulati
       Thank you,
          our team is doing  work on these points and these are in process.
Wed May 15, 2013Post  #2
GULSHAN RAI GULATI
GULSHAN RAI GULATI
Thank You Gupta ji for the reply and hoping to see the same in near future.
2797
1851
Last answer on 7/11/2011 12:00:45 PM. by S L Gupta (Civil Engg). Forum started by KALPANA
3415
SOR
Last answer on 12/30/2021 10:26:27 AM. by S L Gupta (Civil Engg). Forum started by navneet
2511
2362
3614
if i fix some labour rate with petty contractor of covered area of building wit
Last answer on 12/29/2010 12:36:10 PM. by S L Gupta (Civil Engg). Forum started by sudhir singh
2040
estimation
Last answer on 4/30/2013 12:39:09 PM. by S L Gupta (Civil Engg). Forum started by dan
3651
3911
rate analysis
Last answer on 4/17/2021 1:15:59 AM. by S L Gupta (Civil Engg). Forum started by chethan
2336
cost of construction of house
Last answer on 1/13/2014 2:06:06 PM. by S L Gupta (Civil Engg). Forum started by j.B.Singh
2522
Industrial RCC
Last answer on 5/28/2013 10:17:13 AM. by S L Gupta (Civil Engg). Forum started by shikha Chetal
2876
estimation
2419
Paint
Last answer on 6/11/2019 1:36:44 AM. by S L Gupta (Civil Engg). Forum started by mahender
35210
2325
I want to know the rates for delux bathroom with jaguar for 5*6 bathroom
Last answer on 9/17/2013 3:17:17 PM. Forum started by muaz
13783
rcc rate per cubic meter
Last answer on 10/20/2014 12:03:29 PM. by S L Gupta (Civil Engg). Forum started by anks
2118
also want to know the rates of double bed that carpenters charge in lucknow
Last answer on 9/3/2014 2:45:28 AM. by JAI PRAKASH. Forum started by neelam rathi
2275
electric fitting
Last answer on 12/9/2020 5:31:07 AM. by SANJAY DUSANE. Forum started by dspatwal
1994
How to select Mason
Last answer on 2/3/2022 11:34:26 PM. by JAI PRAKASH. Forum started by syedwajidali
3310
Fire
Comparison
Through
Orientation
Orientation of Building
Checklist
Checklist for Painting Work
