Home -> Forums -> Construction -> Basement -> Basement Water proffing
Wed Mar 03, 2010Total posts : 3
Parag Thakar
Parag Thakar
Topic: Basement Water proffing
Dear All
I am planning to Renovate my house . As a first step i have identified to renovate basement. Due to water ingress through walls it is damp from inside. Contractor has suggested to put tiles inside to stop the same. Any other suggestion ? idea.? Will tiles be really helpful ? If yes what type of tiles should i put ?
Fri Mar 05, 2010Post  #1
daljitdhiman
daljitdhiman
u pl go for R.C.C  4" inside supported by 4.5" brick work out side rienforcement 18"x18" 10 mm dia bar on both way, and R C C 2" flooring with rienforcement at 2'x2' both way concrete should mix with water proofing material
Sat Mar 06, 2010Post  #2
jaydeep
jaydeep
Merely tiling your walls from inside will not solve your problem instead it may get more intense. Putting up an R.C.C. wall may be costlier preposition instead opt for crystallization waterproofing techniques which are effective in providing waterproof surfaces when coated from negative side. "Sunanda Chemicals" is one such company that will give you on site assistance
Mon Mar 08, 2010Post  #3
Post subject: Reply- Basement Water Proofing
Dear Parag,
From the contents of your forum, I find that you are renovating your old house. Fixing tiles on the damp wall will be helpful. Good quality or branded glazed tiles should be used. Care should be taken that before fixing the tiles the surface may be well cleaned and tiles should be fixed after applying cement slurry and cement coarse sand mortar in the ratio 1:3.
Dampness in the basement is a serious and common problem. For more help I would like to suggest you to read an article on link below for water proofing treatment for basement.
http://www.gharexpert.com/articles/Basement-1505/Water-Proofing-Treatment-Basement_0.aspx
S.L.Gupta
Basement-Construction Questions (38)
2291
Last answer on 1/5/2022 2:14:28 AM. by JAI PRAKASH. Forum started by chethan
1989
Last answer on 4/26/2015 5:52:24 PM. by JAI PRAKASH. Forum started by chethan
1680
Last answer on 4/20/2015 1:18:43 AM. by JAI PRAKASH. Forum started by chethan
1762
Last answer on 4/20/2015 1:20:37 AM. by JAI PRAKASH. Forum started by chethan
1910
There's a basement space in a building and it locates at backyard of lower level
Last answer on 10/24/2013 11:34:35 AM. by S L Gupta (Civil Engg). Forum started by parth
2467
Retaining wall - Usage of Cement Plasticisers
Last answer on 7/23/2012 11:16:03 AM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
1777
Water Proofing for Basement
Last answer on 5/5/2013 10:44:53 PM. by Abhishek Garg (Builder & Engineer). Forum started by RUSJIM
2757
Construct a sump / basement water tank in drawing / living room
Last answer on 7/5/2011 4:18:52 PM. Forum started by kamalesh
6619
Last answer on 1/7/2022 1:25:49 AM. by Girish. Forum started by Girish
13512
Basement and stilt parking.
Last answer on 7/4/2020 2:21:07 AM. by S L Gupta (Civil Engg). Forum started by R Kumar
4212
Selection of cement ..
2542
layout and planplan
Last answer on 4/21/2015 2:30:45 AM. by JAI PRAKASH. Forum started by abhijeet joshi
1949
Solenoid valves for home water piping
Last answer on 3/10/2013 8:28:59 PM. Forum started by Nilanshu
2028
Water Leakages in Cellar Building
Last answer on 10/19/2015 2:52:35 PM. by vijay. Forum started by Bharat Kumar
1769
Last answer on 8/27/2014 11:15:32 PM. by JAI PRAKASH. Forum started by Sami
1815
Last answer on 8/15/2015 8:17:49 PM. by JAI PRAKASH. Forum started by Devender
1652
1367
Can I make a basement in the face of North East side plot
Last answer on 1/6/2017 12:06:38 PM. by S L Gupta (Civil Engg). Forum started by Mantu
9061
makan map
2774
17223
1993
2157
design of column
2282
2253
Underground water tank
2658
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2798
1970
ffff
1872
4212
3465
2016
Regarding construction
2015
Acid staining
Basement Design Ideas
Vastu Guidelines for Basement
Basement Ceiling
Basement Flooring
Basement Interior Design
Basement serves the purpose of extra space and provides strong base for upper storey.
Comparison
60
60 Tips to Save Water
