Home -> Forums -> Interior -> Bathroom Flooring -> Bathroom tile cleaning
Sat Jun 23, 2012Total posts : 5
vandana
vandana
Topic: Bathroom tile cleaning
Recently we bought a flat on second sales. I want to renew the bathroom fittings, but somebody suggested that engineers know how to get the tiles and comods clean using some chemicals, can you pls suggest me how to get it sparkling clean or shall to renew it!.Need the suggestion urgently.
Sat Jun 23, 2012Post  #1
Swati Satija
Swati Satija
Post subject: Bathroom Tile Cleaning
Dear Vandana
Cleaning of bathroom tiles depends upon the severity of the mold or dirt.
1.Start with spraying the bathroom cleaner from top to bottom. Wet the tiles and spray the cleaner solution.
2. Scrub the entire area with a scrub sponge. Try to focus on the surface of the tiles and not the grout. Scrub the tiles in circular motions and put good bit of pressure. The edges of the tiles need to be scrubbed in straight lines. Wash off with warm water.
3. If you can still see deposits around the tile surface, then try to ascertain the source whether it is due to soap deposits, hard water or the iron content of the water. Most of the soaps give way to a milky film, high iron content in water will cause brown stains to develop and hard water is known to cause green stains.
4. Try to scrub the deposits with white vinegar. Use raw vinegar and make sure to wear gloves as vinegar may cause itchiness. If the tiles become shiny and squeaky clean, then your task is complete.
 If deposits are still there, purchase a bathroom cleaner. There are several special bathroom cleaners for fighting iron and rust deposits.
If this also fails, then try to use a toilet bowl cleaner. Toilet bowl cleaner is known to be very caustic and hence should not be left on the surface for too long. Apply it and scrub it immediately. Avoid applying it on the plumbing fixture as the toilet cleaner may corrode it.
5. For cleaning the grouts, spray some liquid bleach, leave it for some time and wash off after light scrubbing. You may also use a commercial grout cleaner.
Check some more tips for Bathroom Cleaning
Swati
Mon Jul 09, 2012Post  #2
samevans05
samevans05
You don't have to replace your tiles just to make it sparkling clean. Bleach is enough for it. Just let the bleach stay on your tiles for few minutes and scrub it.
Fri Jul 27, 2012Post  #3
davidraju
davidraju
1.Dip a stiff brush in a kerosene and warm water solution to clean bath and shower mats.
2.
Clean after a steamy bath or shower. The walls, fixtures, etc., will be much easier to clean because the steam will have loosened the dirt
3.
For light stains, rub with a fresh cut lemon, For dark stains (like rust) rub with a paste of borax and lemon juice
4.
To avoid bathtub rings, don't use oily bath preparations. Use a water softener if you live in a hard-water area
5.
Rubbing alcohol will clean the caulking around bathtubs. It also shines chrome and glass. Liquid chlorine bleach (1/4 cup to one gallon) will also clean caulk
6.
Clean the toilet bowl while you're away by pouring in 1/4 cup bleach and leaving it until you return
7.
If you have a small bathroom or a tile entrance and don't have time to bother with a scrub bucket, just use an all purpose spray cleaner and a damp sponge for quick clean up
8.
To remove mildew from the corners of the tub, dip cotton balls in bleach and let them sit, when you finish cleaning the bath, remove cotton and rinse well
9.
Remove soap and hard water buildup on shower tile with tile cleaner. Then apply a good paste wax and buff with a dry cloth to deter future water spots.
10.
Rub glass shower doors with a white vinegar-dampened sponge to remove soap residu
11.
Wipe a stainless steel sink with vinegar or a touch of oil on a cloth to make the sink sparkle
Fri Jul 27, 2012Post  #4
HRJ
HRJ
Post subject: Use mild detergent to clean
Bathroom flooring need maintenance from grems, stains, and wet floor.
Use some mild detergent to wash the floor and basins every alternate days.If possible maintain good ventilation so that bathroom remain dry .
Anti skid, germ free, stain free and scratch free tiles are available in market now which may help more.
Attachments: hrj 42.jpg Fri Jul 27, 2012,
b 5.jpg Fri Jul 27, 2012,&n
Thu Sep 03, 2020Post  #5
Cleaning the bathroom is probably not on your list of favourite things to do. But, clean it we must. One of the areas in our bathrooms that can get tricky to clean if we don’t do it regularly is the bathroom tiles.
Whether you have tiles on the bathroom walls or on the floor, learning how to clean bathroom tiles efficiently can ensure you spend as little time doing so as possible. In this article, we provide some helpful tips to clean both wall and floor tiles, as well as how to tackle any mould build up that has formed.
A top tip before you start: turn the shower on to create steam so the tiles are both warm and moist – it’ll make it easier to get any stubborn grime off the surfaces. And, if you’re cleaning with chemicals, keep the bathroom door and windows open for ventilation.
Bathroom Flooring-Interior Questions (29)
2330
14975
Is Jaisalmer stone good for bathroom ?
Last answer on 10/19/2021 11:03:54 PM. by S L Gupta (Civil Engg). Forum started by Radha
3397
Bathroom Cleaning Tips
2172
How to Protect Wood Furniture
Last answer on 9/8/2011 4:16:04 PM. by davidbanks. Forum started by Justin T
2326
Last answer on 11/19/2013 1:31:03 PM. by Amit Hasija. Forum started by Toby Tyler
2350
Need Suggestion
1788
how efficient is a dishwasher for indian style of cooking?does it clean cooker
Last answer on 10/16/2014 12:30:18 AM. by JAI PRAKASH. Forum started by neelam rathi
2213
how to clean sunmica doors
Last answer on 7/15/2021 12:45:52 AM. by HardissonHard. Forum started by Anu
2103
Removal of cement grout from bathroom flooring
Last answer on 4/19/2021 5:32:20 AM. by Purvi Panchal. Forum started by Mrs Francis
3411
Reasons and Ways to Keep the Kitchen Cleaning in Gurgaon
Last answer on 7/3/2020 10:45:19 PM. by JAI PRAKASH. Forum started by yash dahiya
3076
5325
Last answer on 10/8/2015 1:01:18 AM. by JAI PRAKASH. Forum started by nancy
2325
I want to know the rates for delux bathroom with jaguar for 5*6 bathroom
Last answer on 9/17/2013 3:17:17 PM. Forum started by muaz
3291
1315
my bathroom size is 6 5 renovate my bathroom latest design and plan newly
Last answer on 1/31/2017 11:54:36 AM. by S L Gupta (Civil Engg). Forum started by raj
2442
Underground sump finished with granite/tiles
Last answer on 12/26/2014 2:16:16 PM. Forum started by am.sridhara
9157
1489
white bathroom tiles for terrace flooring
Last answer on 10/17/2015 9:47:25 AM. by JAI PRAKASH. Forum started by preeti
1849
Bathroom-water proofing and tiles
Last answer on 12/8/2014 10:03:14 PM. by JAI PRAKASH. Forum started by bhr2014
2103
1933
Sadrahalli
Last answer on 2/23/2021 12:45:32 AM. by sam_m400. Forum started by sam_m400
2519
Bathroom Flooring
Last answer on 12/31/2020 2:15:20 AM. by view interior. Forum started by vijay
2242
1849
1781
My house is under construction and i have to go for plumbing therefore i want to
Last answer on 9/17/2014 10:59:54 PM. by JAI PRAKASH. Forum started by Avinash Sharma
1914
acid wash
Last answer on 3/24/2014 1:45:01 AM. by Purvi Panchal. Forum started by Mrs Francis
2363
2168
Hi, I am planning to put Morward or Agriya marble in my house. Size of the
Last answer on 4/9/2011 7:22:58 AM. Forum started by Rajnish Gupta
1715
Appreciated if i could get some advice on using granite stone and the shade, sin
Last answer on 9/23/2010 11:58:18 PM. by Ar. Manoj Ralen. Forum started by cruz
Tiles
Tiles for Bathroom
Bathroom Pictures
Tile
Small
Small Bathroom Ideas or Tips
Carpet
Carpet Cleaning Tips
Kitchen Cleaning Tips
How to clean plaster ceiling?
Tips for Small Space Bathroom
Bathroom Lighting
