Home -> Forums -> Interior -> Bathroom -> Bathroom with no sunken slab
Thu Jun 20, 2013Total posts : 5
Swaroop
Swaroop
Topic: Bathroom with no sunken slab
Bathroom in an apartment I booked does not have sunken slab. Builder says they are planning to increase the high of bathroom floor by 4", such that waste water can be taken out to sewer line.  I do not like this idea.
I proposed to make half of the bathroom floor raised, and make it as wet area. i.e shower, and closet comes here. Trap can be set on the floor with no issue.
In the remain area, which is not raised, I have to put wash basin.  Water from wash basin can be taken out. But any water spill in this area, there is no trap.  Is it possible to put a trap on lower portion of wall and take it out.. OR any special trap available..
Thu Jun 20, 2013Post  #1
Dear Swaroop
              For the problem you face, I am in view that
1. You have laid the slab than
2. To lay lean concrete under floor than
3. To lay floor as per your choice
In this way you fix floor trap under the wash basin  by chiseling the slab as per your proposal and give slope to words wash basin. Now as per lean concrete thickness it must be 2'', so you can lay 2'' or 2.5'' thick waste pipe for drainage of wash basin and spill water from lower portion.Care should be taken that there should be waste water only not any thick solid so that pipe may not chow k.
Thu Jun 20, 2013Post  #2
Swaroop
Swaroop
Dear Gupta,
1) If I raise the floor by putting 2" concrete, will there be sufficient space to keep a trap ?.  I am under the impression that you need minimum 4" thickness for keeping a floor trap
2) If chiselling slab adviceable  ?. I fear water seepage.  In this proposal how deep I need to make a channel on slab ?
3) I heard there is some special trap available. Don't know the name, but it costs Rs 27000 or so.  Have you heard anything like that ?
Thu Jun 20, 2013Post  #3
      It is necessary to lay lean concrete on the slab under the floor in all the rooms and bath etc.The flooring direct on RCC slab some time cracked in the absence of good bond.
For bathroom take the help of good plumber who can give better solution after visit the site personally.
Sat Jun 29, 2013Post  #4
Better if you keep same level for entire bathroom. let it be raised 4 inches. if you keep it up-down it will be difficult to clean and also will be fear of falling for old people.
Wed Mar 20, 2019Post  #5
rinondavid
rinondavid
good post
Bathroom-Interior Questions (39)
3673
sunken slab
Last answer on 7/3/2020 11:00:06 PM. by S L Gupta (Civil Engg). Forum started by chethan
2148
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara
Related to Sunken Slab
2931
1504
Last answer on 10/31/2017 12:00:07 AM. by S L Gupta (Civil Engg). Forum started by div
3627
sunken slab
2244
hi sir,here is the toilet layout for a house im doing...is there a need for a su
Last answer on 4/12/2015 6:07:10 PM. by JAI PRAKASH. Forum started by amog
2893
Sunken toilet
Last answer on 6/16/2015 4:07:50 AM. by JAI PRAKASH. Forum started by manjula
2449
I intend to put non skid tiles at bath (Sunken Slab) at first floor. Please conf
Last answer on 1/23/2013 1:14:36 PM. by S L Gupta (Civil Engg). Forum started by shahidain
2226
UNIT
Last answer on 7/3/2019 12:34:37 AM. by S L Gupta (Civil Engg). Forum started by sanjoy koley
1849
Bathroom-water proofing and tiles
Last answer on 12/8/2014 10:03:14 PM. by JAI PRAKASH. Forum started by bhr2014
23866
Can we construct toilet without sunken area ? If yes, how to do it.
Last answer on 7/4/2020 1:57:51 AM. by GUNA. Forum started by Kapil Singhal
2115
suppose i take all water pipes through sunken area along the length and breadth
Last answer on 7/23/2011 2:18:10 AM. Forum started by D.Ramachandran
2935
Right price or not .. Kindly advise
Last answer on 7/3/2020 9:28:23 PM. by S L Gupta (Civil Engg). Forum started by everfor
6705
What precautions should be taken while constructing leakproof Slab
Last answer on 5/9/2011 5:23:28 PM. by Moreshwar Kelkar. Forum started by tiwari_p_k
9893
2865
Steel calculation
2421
start construction Steel use
3023
Please send me House plan for plot area 31.66 fit lenth & 25.33 fit width with p
Last answer on 2/11/2022 11:25:30 PM. by Ar. Manoj Ralen. Forum started by Tapsi Yadav
2429
Excellent design.
Last answer on 2/10/2022 1:33:16 AM. Forum started by Tariq
2668
send me the detail of jaccuzi bathtub requirements of room size, expnditure, mai
Last answer on 1/28/2022 9:46:56 AM. by Priti Arora. Forum started by prabhuraj
3119
what is the size of this bathroom
Last answer on 1/21/2022 8:38:51 AM. Forum started by Minal Lemos
2362
What is the brand of this bathtub?
Last answer on 12/17/2021 11:47:36 AM. Forum started by sanda
2462
hw much cost ? tos et this model in my home.
Last answer on 12/31/2020 2:46:35 AM. Forum started by dhaymech@gmaiol.com
2251
i like this picture i have a washroom of220x285 how would u design out
Last answer on 12/31/2020 2:40:44 AM. by Manoj. Forum started by etha
2406
timer switch for exhaust fan
Last answer on 12/31/2020 2:40:39 AM. Forum started by Chacha
2253
Sorry, Scaning one picture was so difficult, i.e. clicking previous, getting t
Last answer on 12/31/2020 2:26:59 AM. Forum started by asha
3594
my bath room size is 9x9 i want green colour bath room fittings is it possible i
Last answer on 12/31/2020 2:26:23 AM. by misha. Forum started by nagarathna
3164
I want to know the budget for constructing a house of 600sq.ft(G) and 900 sq.ft(
Last answer on 12/31/2020 2:22:31 AM. by narendra barde. Forum started by vidhya
10088
how to fit a bath tub in small bathrooms (6'x4')
Last answer on 12/31/2020 1:57:09 AM. by Deepak. Forum started by smruti
2990
details about wall claddings, tiles & all including its rate
Last answer on 10/8/2020 12:45:36 AM. by S L Gupta (Civil Engg). Forum started by laxmi
1926
Any ideas for 7.5 X 12.6 bathroom wanted amenities: small WPtub,medium size with
Last answer on 7/4/2020 4:27:26 AM. by S L Gupta (Civil Engg). Forum started by michelle
2093
interioe
Last answer on 7/4/2020 2:57:31 AM. by S L Gupta (Civil Engg). Forum started by sunil kumar
1823
the bathroom with the japanese tint could someone tell me the brand of the tub w
Last answer on 7/3/2020 11:55:14 PM. by Andy Reed. Forum started by Robert Beachum
2452
Dear Sir, I need double story House floor map of plot size 40x50 front is 40 fe
Last answer on 7/3/2020 11:32:05 PM. by S L Gupta (Civil Engg). Forum started by zahid waseem
3699
Jaquar Whirlpool system
Last answer on 7/3/2020 10:50:29 PM. by S L Gupta (Civil Engg). Forum started by Dharmendra Chouhan
2843
Kindly send a new kayout for 25×30 plot size
Last answer on 7/3/2020 10:34:14 PM. by seema tyagi. Forum started by rajeeva
1942
thank u for ur consideration abt my opinion..could u name the bathroom flooring
Last answer on 7/3/2020 10:33:41 PM. by S L Gupta (Civil Engg). Forum started by Mrs.Meenasiva
Bathroom Pictures
Bathroom Lighting
Bathroom Accessories Part-4
Bathroom Decorating Ideas
Using
