Bending the pillar rods on first floor
Thu Oct 13, 2016
Saneto Fernandes
Topic: Bending the pillar rods on first floor
In our construction of the house the contractor have not put the horizontal beam across the pillars. And beam is separate and column is separate. So is there any problem with it?
And secondly on the first floor the rods of the column are 20 cm ahead of the edeges where the wall will come. So they call outside litl inside of the rooms which waste the space. So can we bend the iron rods and place them in the walls? The main thing is will it have the same strength as what it ought to be if we hadn't bent them?
Please suggest.
Thu Oct 13, 2016
You can tilt the rod/ iron bar as per requirement and fill the cement concrete properly on the tilt portion.
1979
Last answer on 10/13/2016 11:06:46 AM. by
Saneto Fernandes
2695
Last answer on 8/16/2016 11:39:31 AM. by
freekundli
MASTHAN
1345
Bending of rods used in pillars
Last answer on 10/17/2016 12:27:56 PM. by
Saneto Fernandes
3610
Last answer on 8/12/2015 11:59:23 PM. by
jahangir
Last answer on 11/15/2016 1:51:43 AM. Forum started by
K Srinivasan
3793
Pandu
15361
2nd floor construction
Last answer on 7/3/2020 9:53:01 PM. by
bhuvaneshwaran bn
manjuks
Last answer on 11/15/2016 2:10:38 AM. Forum started by
K Srinivasan
1700
on mat iron pillar nos on eastern side -30 feet s are erected and concrete done.
Last answer on 7/29/2014 12:20:16 PM. by
bhushan.k.g.m.
Structure strength to build additional floor(G+4)
Last answer on 12/14/2014 10:12:17 PM. Forum started by
saravanan
2254
Pillar construction
Last answer on 8/17/2013 11:06:12 AM. by
SCK
1661
Foundation Clarification
Last answer on 3/18/2014 12:22:11 AM. by
sivakumar
sivakumar
12462
First floor construction
Last answer on 7/4/2020 12:01:33 AM. by
chidambar
for g+2 floors 12mm 6rods is ok in 1 pillar? or do i need to buy 16mm 6rods in 1 pillar ?
Last answer on 5/24/2017 11:55:40 PM. Forum started by
dreamzy
2390
Last answer on 7/29/2014 12:45:59 PM. by
MANJUNATH
2670
Sreedhar
2891
Pillar distance and steel rod dia
Last answer on 8/1/2014 7:37:46 PM. Forum started by
SAROJINI
2950
Number and position of pillars
Last answer on 7/3/2020 10:41:58 PM. by
Ananda
Ananda
2653
Structure drawing - Is it OK ?
Last answer on 6/4/2011 4:42:55 PM. by
P. Panchal
manjuks
5812
Rakeeb Rathor
3793
Pandu
9885
nasad
2670
Sreedhar
4628
ani
4143
Anamika
2866
lio
ringwang
R.Roy
5008
MANISH
3657
Arvind Bhaskar
premkumarlen
1865
carmenjames
r.n.misra
2801
Sharath Kurva
Sharath Kurva
2610
gk
2374
Adriano Peres
vamsi
2463
nuksung
2638
dayal
1808
TUNDE
3608
ragha
6254
suba
Brick Pillar
Tips for Cement Paint
Tips for Oil Bound Distemper
Sewerage & Plumbing System
Drawing Room Flooring
Epoxy Flooring
Epoxy flooring can be defined as several layers of any type of epoxy resin that is applied on a floor surface. This ty..
