Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Bending of rods used in pillars
Fri Oct 14, 2016Total posts : 1
Saneto Fernandes
Saneto Fernandes
Topic: Bending of rods used in pillars
Does bending of pillar rods on the first floor will reduce the capacity of the rod to hold the weight of the slab on them?
Mon Oct 17, 2016Post  #1
      It will reduce some strength.
1979
Last answer on 10/13/2016 11:06:46 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
2185
Bending the pillar rods on first floor
Last answer on 10/13/2016 11:16:31 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
3610
Structure strength to build additional floor(G+4)
Last answer on 12/14/2014 10:12:17 PM. Forum started by saravanan
2695
1903
roofing
Last answer on 10/14/2015 3:25:36 AM. by JAI PRAKASH. Forum started by sumit
2501
3793
2824
65239
for g+2 floors 12mm 6rods is ok in 1 pillar? or do i need to buy 16mm 6rods in 1 pillar ?
Last answer on 5/24/2017 11:55:40 PM. Forum started by dreamzy
1700
on mat iron pillar nos on eastern side -30 feet s are erected and concrete done.
Last answer on 7/29/2014 12:20:16 PM. by S L Gupta (Civil Engg). Forum started by bhushan.k.g.m.
4431
2095
in concrete piller using more cement sand than20 mm jelly what is the result will be?
Last answer on 5/19/2015 9:17:17 PM. by JAI PRAKASH. Forum started by manja nayka k r
2890
Pillar distance and steel rod dia
Last answer on 8/1/2014 7:37:46 PM. Forum started by SAROJINI
3608
18435
1481
Construction of house with basement.
Last answer on 5/10/2016 11:38:09 AM. by S L Gupta (Civil Engg). Forum started by MUSHAHID RAZA
1484
ABOUT ROD AND MORTAR USED IN THE ROOFING OF THE HOUSE
Last answer on 10/12/2015 10:20:41 AM. by S L Gupta (Civil Engg). Forum started by sumit
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Brick Pillar
Hard
Skylight
Types of Cement
Brass
Brass Doors
Brass doors are very popular for Georgian and Victorian types of architecture in ancient buildings. Today brass doors ..
