Home -> Forums -> Construction -> Bricks -> Brick Advice Urgent
Brick Advice Urgent
Tue Jan 10, 2012Total posts : 4
pmarple
pmarple
Topic: Brick Advice Urgent
HI Guys... i searched around the internet and did not find a proper answer so posting it here.
Im gonna start the wall construction for my house soon and am confused in which bricks to order. I have a choice of, normal burnt bricks, Laterite bricks and Cement Blocks.
Norma burnt bricks or clay bricks is not cost effective i heard so im gonna stick to the other 2 options cement blocks and Laterite Bricks.
Some say cement blocks are cost effective but in the long run the quality decreases. Laterite bricks are strong and less expensive than clay bricks but they say it consumes more cement for plastering compared to cement blocks.
Need some expert advice on Cement blocks Vs Laterite Bricks. Advantages and disadvantages.. Pls..
Thanks in Advance..
Wed Jan 11, 2012Post  #1
Dear Pmarple
Laterite  bricks or blocks are made from laterite stone generally found in southern part of  India. It is soft when wet but on exposure to air it gradually hardens as the moisture between the flat clay particles evaporates and the larger iron salt lock in to rigid laterite structure and become resistant to atmospheric conditions. Nearly all laterites are rusty-red because of iron oxides.
In my view, As stated by you that brunt bricks are not cost effective. Use FIRST CLASS BRUNT BRICKS which have crushing strength more than 105 kg per cm sq and observe water more than 10% after emersion in water for 24 hours. Brunt bricks if laid with proper bond, joint at corner and have good bond with plaster are better than other. The concrete block is cost effective, not give good bond at joints and have no good finish with plaster. The laterite bricks also have same problem and plaster may be weak after some time. Brunt bricks also space saving.
Wed Jan 11, 2012Post  #2
pmarple
pmarple
Thanks Mr Gupta.. it was really helpful.
As i mentioned due to budget and time constraints I cannot go for burnt bricks. I am left with the choice of Cement blocks or Laterite bricks which are both easily available in my locality.  So please help me choose between cement block and laterite brick. All i ned to know is which among the 2 is more durable and gives long life.
And as you rightly said the plastering might become weak after some time. Is there any solution for this issue..??
And one more question. for wooden window frames what suits better .. wood polish or paint?
Thanks for the great advice again.
Thu Jan 12, 2012Post  #3
Dear Pmarple
         Use cement concrete block, for windows frame use hard wood as cost saving or use iron window frame. Painting have more life than polish. polish surface become weak on rain water, sun, heat and cold.
Sun Jan 22, 2012Post  #4
pmarple
pmarple
thanx for the great advice.. really appreciate it..
can you guys give an estimate on the cost for RCC slab for the roof of my house.. the dimension of the house is 30*40 . so the total area of the house would be 1200 sqft... im living in bangalore..
2163
i want office furniture (desk cabin desk & cbinet storege)colour combination of
Last answer on 2/23/2022 1:50:41 AM. by seema tyagi. Forum started by savani
1881
3456
2515
sir send me urgent front design for my house plzzzzzzzzzzzz sir send send on m
Last answer on 3/27/2012 5:00:14 PM. by Swati Satija. Forum started by syed furquan
2019
2849
HOUSE MAP
Last answer on 7/3/2020 10:37:26 PM. by S L Gupta (Civil Engg). Forum started by Pankaj
1801
Hi Dear I need a 15*30 Plan URGENT. Can anyone hlepl
Last answer on 9/21/2015 11:51:48 AM. by Beenu Phogat. Forum started by Manoj
611
There is an urgent need to complete a history task, can someone advise a service
Last answer on 7/26/2021 5:46:43 AM. Forum started by Finn Smith
5135
Use of Solid Concrete Bricks
2991
2017
4179
GLASS BLOCKS / BRICKS
4056
2349
2873
FLYASH OR CLAY BRICK
3928
2706
type of brick
2024
1950
2879
Bricks
2793
brick calculation
2565
Cost of Brickwork
4894
2821
2349
3172
bricks
5658
3237
5135
1624
1341
1845
1479
1797
2966
fly ash bricks
2229
1723
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
