Home -> Forums -> Construction -> Foundation -> Brick Masonry Columns
Mon Jan 13, 2014Total posts : 3
Ilias Ahmed
Ilias Ahmed
Topic: Brick Masonry Columns
Hi Experts
By the grace of God and your Help I have started the construction of my house last week.
My Engineer after putting the footing and erecting the metal rods for columns, he is started building the brick wall around the metal rods and filling with RCC.
This is very new to me as I have seen only complete RCC in the coumns.
Please some one help me to understand and recommend which one is better.
Mon Jan 13, 2014Post  #1
Ahmed
Ahmed
I mean to say there is no shutters around the metal rods instead there is a brick wall, which will be filled with RCC. My engineer says it will be stronger than columns with shuttters
Tue Jan 14, 2014Post  #2
      The proper way is to make RCC pillar with doing shuttering.If your contractor doing with brick wall than the size of column is enhanced which you see is according to the size given in drawing. I think he reduce the RCC size and make it proper by adding brick masonry. He is saving the shuttering.See the link below
http://www.gharexpert.com/articles/Cement-Concrete-1753/Centering-Shuttering--Form-Work_0.aspx
Tue Jan 14, 2014Post  #3
Ahmed
Ahmed
Hi Gupta sir, tks for your reply
The size of the column with RCC is same as mentioned in the plan, the brick shuttering is extra than the size and this is only for the foundation up to ground level after that there will be metal shuttering.
9885
1863
Last answer on 1/5/2022 9:14:05 PM. by sanjay agarwal. Forum started by saradha
1878
column
2159
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by S L Gupta (Civil Engg). Forum started by arctushar
2749
2185
2568
1366
4799
tie beam obsolete
1859
10047
1998
Concrete Hollow Block Masonry
Cost of Foundation
Last answer on 9/11/2012 1:51:22 PM. Forum started by RENJI
3801
Masonry tool ADZE
Last answer on 12/31/2020 1:57:31 AM. by Boovarahan S. Forum started by Boovarahan S
2256
3456
5135
Use of Solid Concrete Bricks
2841
Have a query.I am building a small house in Bangalore. I am planning to do a bri
Last answer on 4/30/2021 11:35:48 PM. by Abra Burks. Forum started by Radha
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2202
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10047
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Brick Arches
Centering
Specification of Brick
Buying tips for Bricks
Buying tips for Brick Blast
