Brick work
Brick or ACC block
Brick or ACC block
Thu Oct 06, 2016
gpeter
Topic: Brick or ACC block
Hello Friends,
Could anyone provide advice on the use of ACC blocks as against bricks. Can ACC blocks be used for load bearing walls? I know they are light and cheaper than bricks and faster to build a wall.
Any information is most welcome.
Thanks in advance.
Gerard
Fri Oct 07, 2016
gpeter
Thanks Kartik,
Your prompt and precice info. is much appreciated. You provided me with what I was seeking.
3433
amit yadav
amit yadav
4179
GLASS BLOCKS / BRICKS
Last answer on 11/10/2021 8:22:17 PM. by
Girish
Girish
3928
Last answer on 7/28/2015 11:31:41 PM. by
nithin
7513
Brick Advice Urgent
pmarple
pmarple
2836
Compound Wall Construction
Last answer on 11/20/2012 3:25:21 PM. Forum started by
honnappabr
13651
Last answer on 1/18/2022 1:46:41 PM. by
Bronx
honnappabr
3145
Last answer on 8/16/2013 1:12:41 PM. by
K S SHYAM SUNDER
3992
Last answer on 7/3/2020 11:38:18 PM. Forum started by
rajeev
5027
600 SFT ACC 2BHK Costing
Last answer on 7/4/2020 4:20:53 AM. by
bharadwaj
2323
so pls sugest eme start new house acc to vastu shastra
Last answer on 12/30/2010 9:09:03 PM. by
king jain
2595
Last answer on 9/7/2012 4:18:47 PM. by
narsi vekeriya
19136
Solid cement block Vs Bricks
Last answer on 6/10/2012 11:29:35 AM. by
jag2
jag
2821
srinu
4211
Selection of cement ..
PRAVEEN G
2266
Cement selection
Last answer on 5/3/2015 7:49:23 PM. by
ashuu
1881
Is a apartment block anti-vaastu if it has a pond on its south
Last answer on 3/5/2021 2:56:01 PM. by
siddhartha
2068
difference betwen block board and ply board
Last answer on 12/31/2020 2:51:40 AM. by
Chetna
manisha
1775
what is the size of blocks
Last answer on 3/20/2012 12:26:58 PM. by
Abdul Salam Reki
3669
wals
shabbir ali
3262
compound wall
Last answer on 7/20/2021 1:24:04 AM. by
Satish Pingulkar
21875
Last answer on 7/3/2020 11:10:01 PM. by
Sambasiva Rao Ravuri
3280
Bedroom Wardrobes information
Last answer on 7/3/2020 9:26:49 PM. by
Meenakshi
2246
Last answer on 5/15/2017 1:39:35 PM. by
mknmohamed
2206
Last answer on 5/2/2017 5:25:23 PM. by
pramod
1494
Last answer on 1/16/2017 3:10:03 PM. by
1965
Last answer on 12/6/2016 1:58:54 PM. by
1732
2224
Last answer on 11/3/2016 11:03:14 AM. by
atulbelokar
2523
1501
Last answer on 10/29/2016 2:54:11 PM. by
Er.S.K.Jain
2025
1653
Last answer on 9/13/2016 2:59:02 PM. by
1702
4687
Brick wall on RCC slab
Last answer on 1/27/2016 11:56:55 AM. by
rajiv sharma
3928
nithin
2617
Last answer on 2/20/2015 6:00:27 PM. by
gurmeet singh
ACC Sheet Roofing
Brick Arches
Specification of Brick
Buying tips for Bricks
