Home -> Forums -> Construction -> Tile Flooring -> Brick tile flooring
Brick tile flooring
Fri May 23, 2014Total posts : 3
Vinay
Vinay
Topic: Brick tile flooring
I am constructing a room on the 2nd floor(terrace) of my house.
The terrace already have a brick tile flooring with soil layer underneath it.
Please guide me if I need to remove this flooring lying before marble or tiles flooring.
Also tell me if i can use PVC flooring on top of this brick tile flooring.
And if yes then what could be the drawbacks of doing so in future.
Fri May 23, 2014Post  #1
Post subject: Remove the Tile flooring and Soil
Hi Vinay,
The Flooring can be done above it but it may reduce the height of the floor by 3-4 inches. The tile flooring can be done above it by using chemical or applying a new layer of plaster above the brick tile flooring. The marble flooring can be done in the same manner but the best would be after removing the Bricks. the PVC flooring can be done easily above it.
Sat May 24, 2014Post  #2
Vinay
Vinay
Thank you very much jai, its really helpful... I think i will  go for the PVC flooring in the open area of my terrace... I think it will be cost effective as well as future proof( in case i decide to cover the open area after 4-5  years. Thanks again.
Mon Jul 13, 2020Post  #3
Thin brick floors are resistant even when wet. The thin brick texture is a perfect balance between ease of clean up and optimal slip resistance. Thin brick flooring tiles are easy to install. Our brick floor tiles install the same way as ceramic tile. You get the beauty of a real brick floor.
Tile Flooring-Construction Questions (38)
2293
7639
Which are various colors of Kota stone for flooring?
Last answer on 3/14/2011 1:41:23 PM. by Mayur Bhurewal. Forum started by Gian Pasricha
6293
brick tile tracing
Last answer on 7/4/2020 2:14:39 AM. by S L Gupta (Civil Engg). Forum started by rahul
3079
3389
3479
labour charges rates
2634
3232
mosaic or tiles
Last answer on 3/19/2013 5:06:52 PM. by Jemimmarichardson. Forum started by aammiitt
3814
3087
flooring
Last answer on 12/16/2015 3:40:28 PM. by JAI PRAKASH. Forum started by arun
2237
paint
Last answer on 6/30/2021 1:46:52 AM. by S L Gupta (Civil Engg). Forum started by jollyjodhaka
1613
Which colour of floor tiles should be fixed as per vasthu
Last answer on 3/14/2017 12:10:29 PM. by S L Gupta (Civil Engg). Forum started by Subbu
1794
Tiles
Last answer on 1/11/2022 5:32:54 AM. by Ben. Forum started by Yuwraj
1878
Last answer on 11/3/2016 10:40:18 AM. by S L Gupta (Civil Engg). Forum started by shashi
1936
1913
flooring
Last answer on 7/28/2016 3:08:23 PM. by Aarav Sharma. Forum started by sumit
32707
Are there any problems in pasting tiles over an existing mosaic floor?
Last answer on 7/3/2020 10:21:35 PM. by Srinaath KS. Forum started by sunilbs9999
3329
3600
Per Sq:ft rate for flooring
3012
Flooring in Car Porch
Last answer on 5/31/2021 3:06:20 AM. by Keira Nail. Forum started by P. Panchal
3522
What is the specification for vertified tiles?
Last answer on 12/31/2020 1:19:32 AM. Forum started by Kamal Jindal
2902
Terrace water proofing
2615
ceramic tle
Last answer on 7/13/2020 12:22:37 AM. by leelindsey. Forum started by sabakhan
3060
Last answer on 7/12/2020 10:44:29 PM. by Girish. Forum started by joseph
2720
Balcony flooring
Last answer on 7/11/2020 8:10:08 PM. by S L Gupta (Civil Engg). Forum started by sdk
2352
Need Suggestion
2293
2625
Tiles
Last answer on 7/11/2020 8:08:42 PM. by freekundli. Forum started by Ahmed
2491
Vest tiles
Last answer on 7/11/2020 8:07:00 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
1673
1496
I need to know more about this tile n price and dealer near by my place
Last answer on 3/5/2016 10:24:39 PM. by JAI PRAKASH. Forum started by Rakesh
1492
white bathroom tiles for terrace flooring
Last answer on 10/17/2015 9:47:25 AM. by JAI PRAKASH. Forum started by preeti
1580
How to Apply Tile flooring in a room
Last answer on 3/24/2014 2:15:29 AM. Forum started by Purvi Panchal
3626
Vitrified Flooring FloorBase on RCC Slabs
Last answer on 5/20/2013 4:10:45 PM. by S L Gupta (Civil Engg). Forum started by Rajesh
2181
down POP designs
2635
tiles
2320
Floor Tile Area difference
Last answer on 7/19/2012 6:28:30 PM. by Ramesh. Forum started by Ramesh
2732
terrace floor tile
Last answer on 9/14/2011 2:03:17 PM. by S L Gupta (Civil Engg). Forum started by nitin dahisaria
Brick Tiles
Flat Brick Tiles should confirm specifications as per IS-1077-1992 and must be homogeneous in texture.
Tile
Tiles
Tiles for Bathroom
Brick Arches
Designing
Specification of Brick
