Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Brick wall and Lintel construction cost per SqFt
Sun May 31, 2015Total posts : 7
DD Gandhi
DD Gandhi
Topic: Brick wall and Lintel construction cost per SqFt
Like to know the following construction cost in Bhubaneswar, Odisha:
1. 10" cement brick wall cost per SqFt.
2.  5" cement brick wall cost per SqFt.
3.  4" thickness Lintel cost ( the roof top chhat) per SqFt
4. The same lintel extended to a Balconey of 15'x5' and 10'x2'.
Sun May 31, 2015Post  #1
Hi DD,
1. 10" cement brick wall cost per SqFt. - Rs. 200/sq.ft with both side plaster
2.  5" cement brick wall cost per SqFt. - Rs. 175/sq.ft. with plaster
3.  4" thickness Lintel cost ( the roof top chhat) per SqFt - Rs 200/Sq.Ft. 4" RCC slab
4. The same lintel extended to a Balconey of 15'x5' and 10'x2'. - Cost will be same.
There may be a difference of 5-10%, the above cost is estimate.
Mon Jun 01, 2015Post  #2
Dear DD
     In my view The rates are as under
1. Wall 10'' with plaster Rs 130-140 per sft
2. wall 5'' thick wit plaster Rs 65-70 per sft.
3.Rcc slab 4'' thick with MS steel Rs 160-170 per sft
Tue Jun 02, 2015Post  #3
DD Gandhi
DD Gandhi
Post subject: Brick wall and Lintel construction cost per SqFt
Dear HLG, JP,
Thanks for the reply. Still I feel the costing for the wall is higher.
A cement brick size of 9"x4"x3.5"=0,073 cft is costing Rs 5.
The wall with bothside plaster: 10"x12"x12"=0.834cft, even we consider it full of brick as the average cost of brick (69/cft), sand (5~30/cft) & cement (300/bag). the material cost of this wall should be-Rs 57/-
Add Labour  charge 20% + Contractor charge 20%--- The cost will come around Rs 80/-
Let me know the real costing for a Parapet wall in FF roof top of size 100ft length with 3ft height.
Wed Jun 03, 2015Post  #4
Dear D D
             The quantity of material for 100feet long 9'' wide and 3feet high wall is= 100x.75x3=225 cft
Bricks=3040 nos
Cement for 1;4 ratio=11 bags
Sand= 56 cft
    Calculate the cost of material asper rate of your city and add labor and sundry charge and contractor profit.
Wed Jun 03, 2015Post  #5
moeen akhter
moeen akhter
hey every one i am new on this blog
Thu Jun 04, 2015Post  #6
Dear Akhter
         welcome on the site.
Sun Jun 07, 2015Post  #7
Welcome
2875
9195
2706
type of brick
2521
construction const
4807
2557
2649
1814
2680
2991
2975
2434
7411
750 Sqft Construction
2708
5856
5663
construction cost per sqft of first floor
Last answer on 5/28/2014 1:55:59 PM. by JAI PRAKASH. Forum started by wrighbed
22926
CONSTRUCTION COST PER SQFT
Last answer on 12/17/2012 5:00:36 PM. by gereddy. Forum started by mctalikoti
5811
3792
9885
2670
4628
4143
2865
5006
3656
1865
2800
2610
2373
2462
2638
1807
3608
6254
Types of arch
