Fri Jan 22, 2016 | Post #1 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Sharma You should construct this wall 4.5'' thick to minimize the load on the slab. The 2nd option is lay 9'' wide and 9'' high beam under the wall to be constructed and beam load goes to the side walls of rooms already constructed.
Fri Jan 22, 2016 | Post #2 | rajiv sharma
Join date: Jul 2015 | Hello Sir, Thnaks for your guidance. We'll have 4.5" wall. Also I wanted to ask one more question. Since the ground floor does not have columns/beams, our engineer planned the first floor walls exactly on the walls of ground floor. Some people are also suggesting to have beams below the walls of first floor. Is it necessay to have beams below the walls or its ok becuase walls are on walls of ground floor. Regards Rajiv | |
Sat Jan 23, 2016 | Post #3 | Pattie Weir
I’m excited to uncover this page. I need to to thank you for ones time for this particularly fantastic read!! I definitely really liked every part of it and i also have you saved to fav to look at new information in your site | |
Sat Jan 23, 2016 | Post #4 | JAI PRAKASH
Join date: May 2014 | Keep walls on walls or take a beam below any new wall constructing.
Sun Jan 24, 2016 | Post #5 | Purvi Panchal
Join date: Aug 2012 | If you make wall above wall, then no need of extra beam at bottom. beam will obstruct at door.
Wed Jan 27, 2016 | Post #6 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Sharma There is no need of beam on the wall as the load is taken by the ground floor wall.
Brick work-Construction Questions (38) | |
