Home -> Forums -> Construction -> Bricks -> Brick workmanship supervision
Sat May 25, 2013Total posts : 1
arctushar
arctushar
Topic: Brick workmanship supervision
Hello
We use RCC Frame structure but Brick for wall partition. All walls r 5? Brick work and size of bricks are 2.75? X 4.5? X 9.5? . Now I have some question
1. At a time maximum what height it should be during masonry work.
2. what will be maximum length ? Do I need to use reinforcement or RCC column after certain interval. Say Can I make 30 feet wall without any intermediate column ?
3. After certain Height do I need to use RCC Bands ?
plze help me and if possible mention reference or calculation. if yes then how
4. What will be the detail of RCC and Brick wall joint detail ( RCC column and Brick Wall adjacent)
Mon May 27, 2013Post  #1
    The brick work may be constructed 3 to 4 feet  in height in one day work.
   If possible and no design compulsion than make 9'' brick pillar in middle of 30' long wall..
 No need of RCC band in wall up to 10' to 12' in height.
Start the brick work with column adjacent to it  i.e zero joint.
1977
Supervision cost
4181
What are the normal fees for architect, civil engineering drawing, quantity surv
Last answer on 5/27/2013 11:48:46 AM. by Vaibhav Jain. Forum started by Anil Sood
2993
2018
4179
GLASS BLOCKS / BRICKS
2350
4057
2874
FLYASH OR CLAY BRICK
2708
type of brick
3929
2417
2866
Bricks
3993
2364
Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Last answer on 7/9/2012 3:21:23 PM. by Ar. Manoj Ralen. Forum started by Lynda
7513
Brick Advice Urgent
3044
Last answer on 8/18/2011 6:51:51 PM. by prasadtvp. Forum started by chella earnest
8249
what are the disadvantages of flyash bricks?
Last answer on 12/31/2020 2:29:47 AM. by H S Rathi. Forum started by gganesan
6286
brick tile tracing
Last answer on 7/4/2020 2:14:39 AM. by S L Gupta (Civil Engg). Forum started by rahul
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2822
2350
3172
bricks
5660
2014
3238
5136
Use of Solid Concrete Bricks
1625
1341
1846
1480
1797
2968
fly ash bricks
2230
1724
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
