Home -> Forums -> Construction -> Bricks -> Bricks requirement for 1000 Square feet Flat
Sat Mar 12, 2016Total posts : 3
sayeedmohsin
sayeedmohsin
Topic: Bricks requirement for 1000 Square feet Flat
My Flat is 1000 Square feet
12’x12’x10’ height wall x 2 rooms
25’x14x10 height wall x 1 hall
7’x4’x10’ height wall x 2 Toilet
7’x10’x10’ height wall x 1 Kitchen
How many brick (normal) of 9 inches required for above mentioned.
How much labor charges for walls
Thanks in advance for your support and cooperation
Mon Mar 14, 2016Post  #1
    The quantity of bricks for 100 cubic feet is 1350 nos i.e length x thickness of wallx height.
Mon Mar 14, 2016Post  #2
sayeedmohsin
sayeedmohsin
Post subject: Bricks requirement for 1000 Square feet Flat
Dear Mr. Gupta,
Many thanks for your reply, I appreciated.
Best regards,
Sayeed
Tue May 03, 2016Post  #3
10x10 walls take 1000 bricks. Costing is around 200 rs/sq.ft. for wall work including material and labour.
2285
thanx before going on to ask for the number of flats drawing may i know in squar
Last answer on 12/28/2012 12:55:21 PM. by Gunjan Utraja. Forum started by Sunil T Deshmukh
1885
discussed about the estimate of of bricks in a wall in one square foot
Last answer on 5/20/2015 5:28:35 PM. by JAI PRAKASH. Forum started by bittushaikh
2125
construct of new house
Last answer on 12/24/2015 4:15:00 AM. by JAI PRAKASH. Forum started by renu
1875
I need 2 Bhk North facing vastu house in 13 square feet
Last answer on 4/3/2017 12:02:32 PM. by S L Gupta (Civil Engg). Forum started by anoop pandey
2124
Need duplex house plan for west facing corner site 20x30 square feet,
Last answer on 10/3/2020 5:12:20 AM. by Saurav anand. Forum started by Anand
2728
546 square feet south face vastu map
Last answer on 11/13/2017 1:47:12 AM. by S L Gupta (Civil Engg). Forum started by ch venkata sai
2103
Types of Windows and Door options in uPVC
Last answer on 5/25/2015 12:51:15 PM. by JAI PRAKASH. Forum started by harsha gv
2633
tiles
2663
I want to know the cost of this flooring per square feet
Last answer on 8/27/2013 12:29:33 PM. by S L Gupta (Civil Engg). Forum started by b.jaganathan
2942
RCC Roof SPAN
Last answer on 5/29/2013 10:29:12 AM. by S L Gupta (Civil Engg). Forum started by Rajesh
2285
I have two plot of 25×40 square feet each. Both 2000 square feet. I want to make
Last answer on 9/26/2015 11:35:59 PM. by JAI PRAKASH. Forum started by Bipin
2793
brick calculation
5755
GC 1310 plan House Plan for 30 Feet by 60 Feet plot (Plot Size 200 Square Yards
Last answer on 8/26/2020 11:41:50 PM. by S L Gupta (Civil Engg). Forum started by ravitej
5045
How to calculate Built Up Area to Carpet Area
Last answer on 7/3/2020 9:39:12 PM. by S L Gupta (Civil Engg). Forum started by ANIL SHAH
1853
for superstructure esstimate
Last answer on 8/17/2013 11:27:56 AM. by S L Gupta (Civil Engg). Forum started by Bs Dhiman
15360
2nd floor construction
1780
my flat bedroom is not perfect square , is there will be any problem.
Last answer on 5/16/2010 7:39:40 PM. by Ramkumar G Krish. Forum started by bikesh
3554
Construction Cost
Last answer on 7/4/2020 12:13:03 AM. by nirmal. Forum started by Balraj
35210
7513
Brick Advice Urgent
2879
Bricks
2793
brick calculation
2565
Cost of Brickwork
4894
2821
2349
3172
bricks
5658
3237
5135
Use of Solid Concrete Bricks
1624
1341
1845
1479
1797
2966
fly ash bricks
1723
Brick Arches
What is acre
Specification of Brick
