Home -> Forums -> Construction -> Start Construction -> Building New Home V/S Buying Builder Flat
Wed Apr 10, 2013Total posts : 5
anand malik
anand malik
Topic: Building New Home V/S Buying Builder Flat
Send some map for 55yards house
The comment above talks about the article   "Building New Home V/S Buying Builder Flat "
Sat Dec 21, 2013Post  #1
Pankaj Malviya
Pankaj Malviya
Post subject: Building New Home V/S Buying Builder Flat
How to start contracting company as a civil contractor in Bhopal. Having 10 year experience in the field of construction.
Sat Dec 21, 2013Post  #2
Pankaj Malviya
Pankaj Malviya
Sun Dec 22, 2013Post  #3
Post subject: How to start contracting company as a civil cont...
dear Pankaj, Hello... I think it is not a difficult task for you to start a construction company as you are already in this line for last 10 yrs. Please start with private contracts under Technical Supervision of Architects/Engineers..
Fri Jan 24, 2014Post  #4
KESHAV NANDA
KESHAV NANDA
I intend to purchase a plot of land of about 300 sq yards in area say it is 90 feet by 30 feet.The very first thing which I have to do is to construct a surrounding wall around it with two gates to the front of the property. I would like to pay the contractor for the materials and labour together. How much will it cost me? Any suggestions will be greatly appreciated! I would like to leave a distance of about 3 feet to 6 6 feet all around my property to make it airy and to make it lit more.And it will keep my costs down There should be room to park at least two cars inside. The actual built up area of the is going to be around 1400 sq feet. All the rooms will have windows and doors at the back and in the front so that there is adequate air and light in the rooms. I like cross ventilation in the rooms. I would be happy to have one large kitchen rather than one kitchen and a small bedroom attached to it. I would rather have less number of rooms than a crammed up house. What I visualize is a corridor of 4 and a half feet width in the middle of the house. There is a flight of stairs going up to the first floor and a door enclosing it. Next after the stairs is the wide entrance( no door here. leading to the dining area of about 15 feet by 12 feet (open plan). The kitchen goes right in the end. The kitchen and dining room and to be separated by a twelve feet wall, The kitchen will measure about 15 feet by 13 feet. At the end of the corridor is a 3 and a half feet passage way which takes you to the right of the building where there are two toilets 6 feet by 3 feet and a 6 feet by 6 feet shower room next to it. Coming to the right of the entrance there is a open plan to a living area. Next to the living area is a bedroom with a door going the passage way and to the front of the property. Coming to the top of the stairs, there are two detached bedrooms on the left, with a 3 and a half feet passage way going through the rooms. There are balconies to the front and back of these rooms. An identical structure goes on the right of the property, making a total of 4 bedrooms on the first floor. 2 toilets and a shower room go on top of the ones on the ground floor. I am a retired person now and I have a budget of Rupees 35 to 40 lacks. Is there an architect who can accomplish my plans? Can somebody come up with a rough design so as to see the minimum cost involved? I can also pay for the rough drawing. I checked with the Ghar Expert that the charges to build a house on 300 sq yard land is about 40 lack rupees and to build on a 155 sq ft of land is going to be comparatively less. Thanks! Keshav Nanda
Tue Apr 01, 2014Post  #5
Dear Anand Malik
2324
2397
is it advantageous to buy flat with stilt 2 floors or stilt 4 floors
Last answer on 7/29/2014 12:12:50 PM. by S L Gupta (Civil Engg). Forum started by Jacob Alex
7196
I'm fond of hunting, so the technique that I buy is quite specific, however I lo
Last answer on 1/5/2022 12:34:54 AM. by HardissonHard. Forum started by RadyGoldy
Modular kitchen new trends
Last answer on 3/31/2012 2:31:04 PM. Forum started by krishan
2316
hai this is ganesh. iam a small new builder. ur site is very helpful to me
Last answer on 1/22/2022 2:11:11 AM. by S L Gupta (Civil Engg). Forum started by ganeshkrg
2351
new design of all materials nd home..
Last answer on 7/14/2012 11:33:38 AM. by S L Gupta (Civil Engg). Forum started by shilpa malik
3347
best ceiling LED LIGHTS FOR NEW HOME IN HARYANA CONSIDERATION VOLTAGE FLUCTUATIO
Last answer on 7/4/2020 3:58:43 AM. by Sushant. Forum started by sanjeev tiwari
2192
PLEASE SEND ME NEW DESIGN FOR HOME WALL & ROOF 10X12 ROOM
Last answer on 10/18/2013 4:07:28 PM. by S L Gupta (Civil Engg). Forum started by PRAKASH KUMAR
3574
construction current rate
2507
1896
hi, need all support to make new homes
Last answer on 5/27/2016 6:17:16 PM. by mukesh. Forum started by Dr Tushar Panigrahi
hi im new home plan frent 36 light 25
Last answer on 7/3/2020 10:19:19 PM. by S L Gupta (Civil Engg). Forum started by sandeep
3501
1752
how to design buildings for flats ..say flats with 3 houses in one floor..like t
Last answer on 4/6/2011 7:39:01 AM. by S L Gupta (Civil Engg). Forum started by D.Ramachandran
2910
Last answer on 1/21/2022 6:49:43 PM. by JAI PRAKASH. Forum started by Suveera
2260
advise
Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque
497
Hello everyone, I would like to buy a new large refrigerator. Who can recommend
Last answer on 2/20/2022 11:03:15 AM. Forum started by Michaell
2296
can start a new building in adi month ?
Last answer on 10/5/2021 8:35:49 AM. Forum started by senthilvel
5390
Need plan for 17.5 * 40 sqft plan
Last answer on 6/19/2014 12:18:34 PM. by seema tyagi. Forum started by Nagajothi
3310
Buying
Buying Guide for Garage Door
Buying tips for Bricks
Buying tips for Brick Blast
Buying
Buying tips for Cement
Mortise
Mortise Locks
Mortise locks become very popular due to high security, easy to maintain and give aesthetic view. The article gives us..
