Home -> Forums -> Construction -> Start Construction -> Building a Budget house
Sun Feb 16, 2014Total posts : 3
Vinay
Vinay
Topic: Building a Budget house
First and foremost i would like to say that this website is very informative and probably the best in indian house construction context.
I want to construct a 2nd floor on my house. the construction area is about 100sq. feet. A contractor has given me an estimate of about 12 -13L(fully furnished).
But I am on a tight budget so I am thinking of building it on my own. I have no experience in house building. So would it be a good idea and if yes then how much money do you think i can save in a very basic structure with ceiling, door, windows and walls if i decide to go without a contractor.
Also if i plan to do so what all challenges can i face.
Mon Feb 17, 2014Post  #1
Dear Vinay
        You first prepare the plan of the house to be constructed, Have detailed estimate and let the work to trough rate or labor rate contractor which will save the cost and give good construction according to your requirement.
Mon Feb 17, 2014Post  #2
Vinay
Vinay
Thank you sir for your reply.
Apart from the cost part what could be technical aspect of construction that should be familiar with before getting the work done on my own. (basically as per my understanding i want to hire a "rajmistry" and do the work of a "thekedar" on my own.
Second part of my question is " is it possible to get technical help for hourly or daily basis?"
Tue Feb 18, 2014Post  #3
Dear Vinay
      For the help you require contact local your city engineer or mason.
2033
It need to thinks for middle class people with innovative ideas to build such ty
Last answer on 12/12/2010 12:25:15 AM. Forum started by S Borthakur
12146
41*43 sqr ft north face only850sq ft small budget house
Last answer on 11/23/2016 12:00:28 PM. by Beenu Phogat. Forum started by kannan
3080
3139
I want to know the budget for constructing a house of 600sq.ft(G) and 900 sq.ft(
Last answer on 12/31/2020 2:22:31 AM. by narendra barde. Forum started by vidhya
1490
How to calculate budget of a complete house in item wise.
Last answer on 7/2/2020 9:26:37 PM. by S L Gupta (Civil Engg). Forum started by kulothungan kk
1779
Last answer on 8/29/2016 12:10:36 PM. by S L Gupta (Civil Engg). Forum started by vishal
1790
Want to construct a new house in limited budget, area 35*35 .
Last answer on 10/20/2015 2:24:22 AM. by JAI PRAKASH. Forum started by Kiran
1871
sir i want to bulit a hose in low budget in 1500sqf in my village what is max bu
Last answer on 1/5/2022 1:01:29 AM. by HOME. Forum started by k. santosh reddy
8030
Modern Kitchen
Last answer on 2/19/2022 3:13:17 AM. by Gohkadd. Forum started by ankita
2258
Hi, Having a plot of 30x50 facing road 53 degrees from north, so assuming northe
Last answer on 3/12/2014 2:46:09 PM. by satishb. Forum started by satishb
1874
Budget for new 4 storage building
Last answer on 11/17/2014 7:06:11 PM. by JAI PRAKASH. Forum started by jayanta
3194
Please give me a good looking low budget 10x12 bed room furnishing with all requ
Last answer on 6/11/2012 5:22:27 PM. by Gunjan Utraja. Forum started by Mandeep Sharma
4254
any gud designer for modular kitchens in bangalore
Last answer on 7/4/2020 2:23:27 AM. by Dinesh Mittal. Forum started by pv rao
604
how to choose a budget and fast internet?
Last answer on 2/15/2022 7:08:19 AM. by manita. Forum started by Salammm
5097
How to decorate my house
Last answer on 11/19/2019 11:25:42 PM. by . Forum started by Satvinder kaur
2251
Last answer on 7/4/2016 5:42:09 PM. by S L Gupta (Civil Engg). Forum started by Aniket
6133
1571
i want to build 300 sqft houuse want a elevation model house
Last answer on 7/3/2020 11:49:54 PM. by S L Gupta (Civil Engg). Forum started by vimaladevi
867
AYAA IS NECESSARY TO BUILT HOUSE
Last answer on 7/4/2020 2:57:20 AM. Forum started by SATISH
2451
3274
3285
4429
3975
2197
2699
4210
5168
2378
2294
1996
2447
2114
3195
2047
12514
2164
2010
2726
Orientation
Orientation of Building
Environmentally
Environment
Environment Friendly Houses
Protect
