Home -> Forums -> Construction -> Foundation -> COLUMN & BEAM WIDTH & HEIGHT REQUIRED
Wed Jan 13, 2016Total posts : 3
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
Topic: COLUMN & BEAM WIDTH & HEIGHT REQUIRED
Dear Sir/Madam,
It is requesting u all please advise me that what would be width & height of column & beam to build a g+3storied building.Where how many steel have to put in every column & beam.
Durjoy
9933021800
Attachments: PROJECT OF 1ST TO 3RD FLOOR.xlsx on Wed Jan 13, 2016,&n
Thu Jan 14, 2016Post  #1
Dear Mondal
          It is better to get proper structure design. If you want tentative than for 4- story house keep the size of column and beam at least 12''x 18'' with MS Steel not
less than 20mm diameter.
Thu Jan 14, 2016Post  #2
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
Post subject: DEAR SIR (S.L. GUPTAJEE)
Respected sir,
Pls provide me in detail the steel diameter for column & beam also.Al so it requesting to u that confirm me as per attachment.How many column would be required sir?
Sat Jan 23, 2016Post  #3
The minimum diameter for beam is 16 mm and for lantel is 12 mm/10 mm.
5193
3827
Roof Beam
1292
1807
I want to change front design of my house
Last answer on 8/15/2020 12:59:30 PM. by tiyas. Forum started by Adnan Saifi
3260
2976
2696
2682
2249
STEEL BEAM & COLUMN
Last answer on 1/12/2016 12:30:46 AM. by JAI PRAKASH. Forum started by DURJOU KUMAR MONDAL
1923
2165
New column footage and pillar very next to the wall of existing building
Last answer on 10/30/2014 5:27:13 PM. by Rachael Suggs. Forum started by Robert
2336
9" brickwork Compound wall length of 25ft and 7ft height with out beam / columns
Last answer on 8/21/2017 1:06:37 AM. by S L Gupta (Civil Engg). Forum started by Prakash
1348
1932
2364
2634
please send me some sample plot size of 18ft width and height 60ft. thanks.
Last answer on 8/14/2012 2:29:54 PM. by Gunjan Utraja. Forum started by gurmeet singh khaira
10029
2656
Pillar
2126
Curing urgent
2346
structure work
5151
Pillar foundation
new house
2806
building a house
1980
Construction Agreement
3082
Foundation
2260
Foundation
1464
10029
3647
Foundation
2102
Structure proof checking
2545
Foundation design
2430
2455
Saria and cement
3634
Wall Thickness
2659
3144
13244
Steel Type
Centering
Designing
Designing a Foundation
