Home -> Forums -> Construction -> Start Construction -> COLUMN nd LOAD BEARING
Thu Apr 28, 2016Total posts : 2
Shivaraj
Shivaraj
Topic: COLUMN nd LOAD BEARING
HI,what is defference between Column Structure nd Load Bearing in House construction
Thu Apr 28, 2016Post  #1
Dear Shivraj
       The load bearing structure is that all the load is bear by the walls where as frame structure building is that all the load is bear by the column and walls are either partition wall are non load bearing.
http://www.gharexpert.com/tips/articles/Construction/1644/Cement-Concrete-1644-Column-Frame-Structure-Building_0
Thu Apr 28, 2016Post  #2
Shivaraj
Shivaraj
Thanks A Lot Gupta Sirji.
10056
3946
1767
7271
3016
3552
Installation of solid load bearing granite/sandstone columns.
Last answer on 4/19/2012 12:05:30 PM. by Rajan S.Raj. Forum started by Rajan S.Raj
10322
900 Sqft column required
Last answer on 7/21/2021 11:11:14 AM. by S L Gupta (Civil Engg). Forum started by Shivaraj
2221
4139
4956
LOAD BEARING STRUCTURE
2263
7937
3430
2133
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by S L Gupta (Civil Engg). Forum started by Syed Shahed
1926
please give me an idea
Last answer on 2/18/2013 1:18:56 PM. by S L Gupta (Civil Engg). Forum started by nithya
3008
i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
Last answer on 9/19/2013 2:12:08 PM. by manishkumar. Forum started by manishkumar
1898
Structural design
Last answer on 7/3/2020 10:29:46 PM. by S L Gupta (Civil Engg). Forum started by Akhil George
2479
3302
3318
4449
4018
2243
2722
4233
5204
2392
2318
2021
2463
2140
3213
2070
12538
2185
2029
2748
Specification of Steel
