Layout and House Plans
CONFUSED BETWEEN TWO DIFFERENT FLOOR PLAN.
Thu Oct 15, 2015
chitta naik
Topic: CONFUSED BETWEEN TWO DIFFERENT FLOOR PLAN.
I am planning to build a house under 1500 sq.ft. but confused between two plan. can any one suggest , which is the better to build ? as per vastu and all point of view . please view attachment below .
PLAN (A).jpg on Thu Oct 15, 2015,
PLAN (B).jpg on Thu Oct 15, 2015,&n
Thu Oct 15, 2015
Dear Chittha
Adopt the plan which is best suited to you and your family as you to live in the house.
In my opinion plan B is better option.
Thu Oct 15, 2015
chitta naik
dear gupta sir,
Thank you for you opinion. my another question is that 11 x 11 bedroom size is good or not .
Thu Oct 15, 2015
Good size would be 12x10 or 12x12.
Fri Oct 16, 2015
Post #4
Dear Chitta
If space available than increase the size other wise it is ok.
2048
Last answer on 5/9/2016 11:34:49 AM. by
soumya
2239
Flooring for house
Last answer on 1/17/2022 11:13:36 AM. by
Archit Jain
6772
Best elevation deisgns for west facing two floor house with 30 x 45 feet
Last answer on 4/22/2021 2:52:43 AM. by
K.Ashok Kumar
1776
Last answer on 2/3/2024 1:42:16 AM. Forum started by
Alfie Solomons
10313
i have a plot of 40x60 north facing plot where i need a two bed room house duple
Last answer on 7/4/2020 2:45:48 AM. by
2BHK FLAT - TWO PORTIONS - TWO FLOORS - 110 AQ YRDS
Last answer on 1/13/2014 2:21:22 PM. by
Hemant Tiwari
1633
I need a house plan for 25×40 feet.North facing.but only for ground floor.i want
Last answer on 4/4/2018 1:18:43 AM. by
Gujjalaraja
2728
Wooden Flooring
Last answer on 2/9/2021 5:39:37 AM. by
Prakash Pandey
atiq khan
1966
what are the different good wooden flooring options available...pl suggest
Last answer on 5/23/2011 10:12:30 PM. by
Reena
2238
Costruction of different ground and first floor plan
Last answer on 7/9/2012 10:44:48 AM. by
Ar. Manoj Ralen
Aamir
Last answer on 11/15/2016 1:51:43 AM. Forum started by
K Srinivasan
1497
SirI have a 60-52 feet vacant site I would like construction ground and another
Last answer on 3/23/2016 3:43:42 PM. by
SUDHAKAR
2209
Review my plan
Last answer on 3/18/2014 1:23:04 PM. by
satishb
2625
New Construction in 40 width 70 length west facing plot
Last answer on 2/27/2015 4:07:48 AM. by
Ramesh Mayakoti
1753
Last answer on 10/26/2015 11:57:26 AM. by
sigamani
Last answer on 11/15/2016 2:10:38 AM. Forum started by
K Srinivasan
4376
Last answer on 10/6/2011 1:11:14 PM. by
ramesh
ramesh
2313
i have provision for 3 bedrooms ,one on first floor in south west direction whic
Last answer on 11/7/2021 11:26:13 PM. by
Nitien Parmar
Reena
2719
terrace floor tile
Last answer on 9/14/2011 2:03:17 PM. by
nitin dahisaria
2674
Raj
2176
Amutha
2169
vanramr
2766
raghu
4495
Nitien Parmar
suryarao p
1875
santosh
2272
Deepak Giri
2243
ajay sharma
2749
u v sudhakar
3450
ramana
2345
srinivas kamsali
1949
tanaya483
2209
ramanapeddu
3583
SRIKANTH.S
HIRA SINGH
2782
Alexander Graf
Mohiuddin
1537
uma shankar
2109
mohammedbasha
Tips for Oil Bound Distemper
