Tue Aug 13, 2013Total posts : 1
K S SHYAM SUNDER
K S SHYAM SUNDER
Topic: WHICH CONST. MATERIAL BETWEEN BRICKS AND SOLID BLOCKS IS A BETTER CHOICEFOR RESI
WHICH CONST. MATERIAL BETWEEN BRICKS AND SOLID BLOCKS IS A BETTER CHOICEFOR RESIDENTIAL HOUSES
Fri Aug 16, 2013Post  #1
Dear Sunder
      If first class brunt bricks are available than these are good, than blocks.
http://www.gharexpert.com/articles/Bricks-947/Bricks-Quality_0.aspx
3433
19138
Solid cement block Vs Bricks
Last answer on 6/10/2012 11:29:35 AM. by jag2. Forum started by jag
3842
2061
Last answer on 10/15/2014 8:31:38 AM. by SANJAY DUSANE. Forum started by naresh
4179
GLASS BLOCKS / BRICKS
3929
7513
Brick Advice Urgent
3457
4057
2836
Compound Wall Construction
13651
2533
cost of plaster a block wall
Last answer on 2/27/2013 10:58:41 AM. by S L Gupta (Civil Engg). Forum started by kamlesh
5135
Use of Solid Concrete Bricks
2466
3046
Which would be a better options for apartments (medium and high rise) Concrete Tanks or Sintex Water tanks
Last answer on 10/20/2010 3:34:11 PM. by . Forum started by savietha
2595
Last answer on 9/7/2012 4:18:47 PM. by S L Gupta (Civil Engg). Forum started by narsi vekeriya
2866
Bricks
3993
18
Specification of Brick
Brick Arches
KITCHEN
"KITCHEN"THE POWER HOUSE
SOUTH-EASTCORNER IS SUPPOSED TO BE THE PLACE OF LORD AGNI,GOD OF FIRE.
