Home -> Forums -> Construction -> Start Construction -> CONSTRUCT A NEW HOUSE PLAN
Tue Apr 24, 2012Total posts : 1
sanjay
sanjay
Topic: CONSTRUCT A NEW HOUSE PLAN
I HAVE A LAND OF 40*50 feet.i want to make a double story housewith following
1. one kitchen
2. pujja ghar
3. one lobby
4. two bed room
5 .two toilet
6.garden
7.one guest room
8 open space
9. stairs
10. parking for car
plz give me design for the home as u provided in the attched images with this request
thanks---
emaIL ID----sanjaygera764@gmail.com
Attachments: 61201172929.jpg on Tue Apr 24, 2012,
215201152429.jpg on Tue Apr 24, 2012,
427201130944.jpg on Tue Apr 24, 2012,
519201132517.jpg on Tue Apr 24, 2012,
12292011111314.jpg on Tue Apr 24, 2012,&n
Thu Apr 26, 2012Post  #1
Post subject: Browse the floors plans and send us your choice ...
Dear Mr. Sanjay,
We have launched a very cost effective architectural plan service that is available at the link below:
The plans that matches your requirement are follows:
In order to purchase architectural plan through this service, please use the steps below:
  • You select a plan whose layout you like. Note down the plan code and purchase the plan.
  • Once you purchase the plan, we will contact you and send you a questionnaire through which we will understand your requirements.
  • We will assign a representative for your project and he/she will coordinate all your requirements.
  • After discussions with you, we will adjust the plan according to your exact plot size and make as many changes as you like. Our prices are based on per square feet of built area and if after changes your built area increases by more than 10% then we will change for the increased area accordingly.
  • If you also purchase guidance from Vastu expert then an independent vastu expert be assigned to your project and he/she will review your plan and suggest changes.
  • Once the plan is finalized, we will give you dimensions as shown in the sample drawing and door window schedule.
  • If you purchase more drawings then the same will be delivered to you according to the plan finalized by you.
  • If you choose a 3-D option too, then the process works as below.
    • After completion of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
    • Based on the architectural plans and your preferences, our 3-D designers will design the 3-D elevation for your home.
  • If you purchase, 3-D elevation plan then you should also purchase the 2-D elevation plan as all dimensions and levels are provided in the 2-D elevation plans. Your contractor would use the details in the 2-D elevation plan to construct your home. The 3-D pictures are there for a reference so that both you and your contractor can visualize the same thing.
  • If you have a question, then feel free to call 08295820011, 08295820022 or send an email to Support@GharExpert.com
2309
New Home
2447
5956
new construction in 300 sq yards place ...planning
Last answer on 2/20/2011 12:22:40 PM. by Gunjan Utraja. Forum started by vihal madishetty
2107
Last answer on 11/21/2015 12:12:42 PM. by SACHIN. Forum started by SACHIN
2647
5166
1832
Last answer on 9/8/2021 6:08:07 AM. by S L Gupta (Civil Engg). Forum started by Gujjalaraja
2474
3261
Last answer on 7/2/2009 1:17:27 PM. by . Forum started by murtazamalik
2022
2962
1801
Want to construct a new house in limited budget, area 35*35 .
Last answer on 10/20/2015 2:24:22 AM. by JAI PRAKASH. Forum started by Kiran
1779
sir.iam in tamilnadu.we started to plan build new house in 900 sq.ft.i need some
Last answer on 7/27/2016 2:34:54 PM. by Beenu Phogat. Forum started by madhu
9961
1218
Sir i m planning for new house .. which wooden frame is best sal or teak or deod
Last answer on 8/16/2018 2:03:02 AM. by S L Gupta (Civil Engg). Forum started by Shivam gupta
3501
6440
Column placement for house
3317
Last answer on 5/1/2012 11:09:41 AM. by S L Gupta (Civil Engg). Forum started by pankaj sharma
14267
Demolition of Old house and constructing New house
Last answer on 1/21/2011 11:04:22 AM. by Archit Jain. Forum started by Kanchana
3310
Happy
Happy New Year 2009
Happy
