Home -> Forums -> Construction -> Start Construction -> CONSTRUCTION COST PER SQFT
Sun Dec 02, 2012Total posts : 3
mctalikoti
mctalikoti
Topic: CONSTRUCTION COST PER SQFT
|I want your advice on following. I have hired a contractor, who is charging me 1450 rs/sqft for building my house. & he is charging for Slab projections Rs 800 per Sq ft.  Please advise on this.
He is not giving detailed estimate of the project. we have built up are 1630 Sq ft , then he is multiplying by 1450 Rs / sq ft + 320 Projectionsx800 rs
=2363500+263200
=2626700 Rs will be the contract amount excluding compound wall.
 This site is 40'x60'. Built up area is 1630 Sq Ft. In Bagalkot Dist. Karnataka India.
Please advise me on the cost of the building. Is the contractor is correct or wrong.
Waiting for your reply
Best Regards
M.C.Talikoti
Wed Dec 05, 2012Post  #1
The proper way of finding the total cost of the building and rate per sq feet is that to have detail estimate according to the drawing of your home, in which you are able to know about rates and cost of the building.After having details of each items and material you are in better position to bargain with the contractor. See the link below.
Sat Dec 08, 2012Post  #2
Raviteja
Raviteja
1450 per sft is an exhorbitant cost for your area
Slab cost which is 800 per sft which is 55% of the total cost is comical...
Generlly construction costs including everything will not cross 1200-1300sft....Including wood work-sewarage-tiles-paint etc.....
Slab cost will not cross 600 per sft for residential houses (40-50% of total cost)
Untill u see the detailed estimate , don't commit to the contractor.Spend 25,000/- to 30,000 /-on a consultant of your choice who can guide you to save money because if you save 100 per sft your saving is Rs 1,63,000/-
Mon Dec 17, 2012Post  #3
gereddy
gereddy
@Raviteja,
I also recvd same quote around 1400-1500 in bangalore
if contractor has given 1450 psft in bangalore..is it still expensive? also this does not include wardrobes
5662
construction cost per sqft of first floor
Last answer on 5/28/2014 1:55:59 PM. by JAI PRAKASH. Forum started by wrighbed
11557
Brick wall and Lintel construction cost per SqFt
Last answer on 6/7/2015 1:27:14 AM. by JAI PRAKASH. Forum started by DD Gandhi
3778
cost for construction for a new home
Last answer on 1/10/2013 4:08:03 PM. by sapan. Forum started by sapan
4807
2648
2680
5856
2707
7410
750 Sqft Construction
2432
2974
2521
construction const
23866
2745
18378
Hi ...Estimation of per sqft construction of a house on 900 sqft in Bangalore..Uttrahalliarea
Last answer on 6/20/2011 12:51:37 AM. by SUSHEEL. Forum started by arindam
4244
Last answer on 7/3/2020 11:17:06 PM. by Kanhaiya. Forum started by rahul
7101
Cost of stilt floor construction
Last answer on 10/1/2009 3:08:55 PM. Forum started by Amar
2705
type of brick
3310
2133
2059
Various
Importance
